Question about Epson - PowerLite S1+ Multimedia Projector
Epson powerlite 83c bulb comes on dim will not
Epson powerlite 83c bulb comes on dim will not get bright until teacher turns off and on multiple times.
  • 27 Answers
SOURCE: epson powerlite 7700p video problems
could be, colour change is typical of a pj lamp expiring.
check first the connection lead between pc and pj
to make sure pj is seeing all signal pins on sub d lead.
check pj with video sig input, if thisis ok it's not the lamp failing
Posted on Feb 26, 2008
  • 14 Answers
SOURCE: proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Posted on Sep 14, 2008
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
projdoc
  • 2237 Answers
SOURCE: Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
Posted on Nov 19, 2009
BILLatNASA
  • 3 Answers
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250
Reset the lamp counter hours in 3 steps
1. Make sure, your projector is ON
2. Hold down the Help and Menu buttons for 5 seconds.
The "A.S." screen will appear.
3. Hold down the Tracking and Tracking - buttons for 5 seconds.
Posted on Sep 20, 2010
I changed the bulb on my epson powerlite 83+ and now there is a blurry spot in the middle of my screen. Is there anyway to fix this?
For anyone that may still stumble on this post, we have two of these and the blurry spot is most likely caused by the neutral density filter in front of the Green LCD element. We still haven't found a source for this part, but it seems to be caused when the bulb overheats and melts the plastic filter causing it to warp and wrinkle.
Jun 09, 2012 | Epson PowerLite® 83c LCD Projector
I have an epson 83c, I have a flashing red lamp light
Hi!
You need to replace the lamp of your projector.
Hope this helps.
Mar 17, 2011 | Epson PowerLite® 83c LCD Projector
Projector will not turn on. Lamp light displays red and temperature light displays red.
I'm sorry to inform you that there is an internal error in the projector. Turn the projector off and unplug it. Contact Epson for help.
Feb 27, 2011 | Epson PowerLite® 83c LCD Projector
My Epson proxima is displaying pink. I did reset and replace cables and bulb. Any suggestions
I've seen the screen go pink when the video input is set to the wrong type (composite instead of RGB). Try each input type to see if it goes away.
Jan 25, 2011 | Epson PowerLite® 83c LCD Projector
Epson powerlite is display is green when projecting form a computer
HI
problem with main board conatec service centre
M.R. Mumbai & Dubai
Sep 01, 2010 | Epson PowerLite® 83c LCD Projector
Projects upside down
go into the menu and reset the setting to factory default.
Dec 17, 2009 | Epson PowerLite® 83c LCD Projector
One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
Dec 09, 2009 | Epson POWERLITE 400W Projector
Nov 10, 2009 | Epson PowerLite® 83c LCD Projector
Epson 83+ powerlite projector overheat
hi follow the link bellow the instructions are on page 83 \\files.support.epson.com/pdf/pl83pl/pl83plug.pdf
Jun 04, 2009 | Epson PowerLite® 83c LCD Projector
Epson - PowerLite S1+ Multimedia Projector Logo
384 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
