Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker leaking inside freezer compartment, water dripping down from unit
  • 4,059 Answers
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Posted on Sep 23, 2009
Ice maker water tube has ice in it
Hi David, if you are finding that the ice maker fill tube is clogged with ice, you may have a defective water valve. Sometimes water valves leak small amounts of water and drip by drip it freezes when they enter the freezer compartment. Clean the iced up fill tube and if it happens again you will need to replace the valve. Good luck.
Oct 19, 2013 | GE Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icicle are forming around icemaker port inside of freezer compartment drips seem to come from around inmaker feed water area.
Sep 17, 2009 | Kenmore 53642 / 53644 Side by Side...
Leaking ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
241 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
