Question about Pool & Spa
Have a Hayward Mod.#36C68/H400. Unit comes on, gas is on then goes off after 5 sec. DE filter is showing 30 PSI. is this to much pressure? Is it the gas valve? How old is this heater? I am a pool tech. Need a on line copy of trouble shooting guide. Thank you, Dennis. dennis@asdpoolsupply.com
    President:
  • 1,378 Answers
Manual. Try page 35 on down.
Posted on Sep 24, 2009
Lo showing on display won't start
you have an open safety circuit. usually the pressure switch. clean out pump basket, back wash filter to start. you may have a faulty pressure switch
May 02, 2014 | Hayward H-series Electronic Gas Pool...
Error code
make sure water filter is CLEAN ! this will throw a code
Jun 22, 2013 | Hayward H-series Electronic Gas Pool...
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
The pressure gauge on top of the filter only reads 5 psi. I backwashed and added DE and it still only reads 5 psi. It also read 5 psi after filter was backwashed and before DE was added. What prompted me...
Is there good water flow? Can you feel good flow at the pool return?
If so, using your hand, try to stop the flow. Does the pressure go up?
If the pressure goes up, something inside the filter is not presenting resistance to flow as is normal; it could be a broken element, etc.
If there is no flow or if the pressure doesn't go up, make sure that there is no obstruction in the line coming from the pool to the pump. Check the inlet basket, inlet strainer in the pump, look for debris in the pump inlet & pump outlet piping.
Gary
Aug 20, 2011 | Hayward 1.5 Hp Northstar High Performance...
My Heater shows low pressure reading but I have 13lbs pressure flow through? This is a electronic control unit that about 2 years ago it stopped being able to be adjusted for tepmerature. Is this a related...
Your temp problem probably has nothing to do with this. Usually it will just be a temp. sensor. A simple and cheap fix.
As far as the pressure goes, the higher the pressure at the filter the lower it is at the heater. So don't go on the filter pressure alone. If it reads pressure problem always clean the filter first. Next you should check to be sure the impeller isn't clogged. Then be sure you don't have a by-pass valve that is open.
Dec 04, 2010 | Hayward H-series Electronic Gas Pool...
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
Recommend backflush pressure of a hayward pool filter
After you have backwashed your filter until the site glass run clear. Go to rinse mode for 30 seconds. Make note of the filter pressure. Don't backwash until the pressure goes up 10 psi!! It is important not to backwash too much. As pressure climbs the sand filter actually filters better.
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hauward H400 heater won't turn on
check pressure switch operation most heaters will not operate without sufficient water flow/pressure. You can use a multimeter to troubleshoot the wiring using the schematic. If its induced draft milivolt ignition verify there is suffiecient gas flow to the unit
May 25, 2009 | Hayward H - Series 400 Heater Top for In -...
Pool & Spa Logo
277 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
