Question about LG WM-2277HW Front Load Washer
Upside down backwards fE comes on. We had a
Upside down backwards fE comes on. We had a repair man tell us it was the pcb board. WE replaced it and it is still doing the same thing? What would you suggest next
  • jheadman Sep 23, 2009
    This wasn't helpful because it isn't an FE it is a backwards upside down FE I don't know how else to write that. I have changed the PCB board and the Hull sensor and still getting the same thing. It seems to have problems in the spin cycle.
  • 15,935 Answers
The error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a aservice call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try. There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
remove or disconect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)...
If you still get the FE test..call for service..
BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open.
CLICK HERE for the WM series service manual that may help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2009
  • blueextc3221
    blueextc3221 Sep 25, 2009
    WHooaaa...I just checked the error code again to make sure and it's actually and FE error (actually an upside down 'F' as the first letter - according to a manual says it's the THERMISTOR is out of order.
    That code is a heating error - thermistor
    You can check to see if the wiring to the heater and quick connect plugs to thermister are ok.
    Those parts can be changed by you if you took the back and motor off
    CLICK HERE for the thermistor.
    Thanks for using FixYa - please re-consider rating to 4 THUMBS for answering your FREE question.
    Thank You.
How to know circuit board is gone
You should of asked the repair man to show you the damage on the PCB. If he said it is damaged, why are you asking this question? Do you not believe him?
Dec 23, 2015 | Haier Washing Machines
How do I remove the Main PCB from an LG LMU24CHV note not 247HV
Very easy. Use knoseplayer and hold both broken plastic together and then slowly remove ur board. Tnq
Sep 02, 2015 | LG LMU247HV Air Conditioner
Dishwasher won't run much of the cycle.
LG dishwasher 2009 lds4821bb, water does not heat up anymore. thanks
Jan 26, 2010 | LG Dishwashers
DVD plays upside down adn backwards
Re-check the wires to start with mate
May 31, 2009 | Car Audio & Video
1998 vw cd changer reads "chk magazine" or"cd err" help!
Unplug it for about 5 minutes and plug it back in and pray to the vw cd changer Gods to allow it to play again.. By unplugging the unit AT THE UNIT will result in a hard Boot. Now if it is still not happening than it's time to call the repair man, also be sure the magazine is inserted correctly. I couldn't tell you how many customers came in with the magazine upside down, *** backwards, cds loaded upside down, etc but try unplugging it 1st. good luck. but let me ask you why you messing with a changer when you probably don't own but 4 cd's and all your music is on your iPod?? Peace. Mark @ Sounds Good to Me . Tempe, AZ
May 06, 2009 | Car Audio & Video
Image is upside down and words backwards
malfunction in the camera and will need repair
olympusamerica.com/repair
Oct 17, 2008 | Olympus FE-210 Digital Camera
Samsung HCM653W 65 in. Television
Dear,
I do not know, what the problem you have in your tv M/N:HCM653W. I have the same Model samsung tv. I have image ghosting problems. As per tech I replaced the Pcb,sub.samsung part AA95-01846D, Which did not fix the problem. I still have it for sale. The power supply pcb is no longer availabe as per"Partsstore.com. I have no idea where you can find the power supply board. If you find it,please let me know.
Thanks.
DollarTech
Jun 18, 2008 | Samsung HCM653W 65" Rear Projection...
Picture is upside down and backwards
I have the same problem. How and where does this come from? My camera was sitting in the dock when I noticed the problem!!
Nov 26, 2007 | Kodak EasyShare C315 Digital Camera
LG WM-2277HW Front Load Washer Logo
629 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
