Question about Sony VAIO RA820G (VGCRA820G) PC Desktop
Does it matter which sata input i plug my main hard drive in
There are 4 ,2 up and 2 down?
    President:
  • 788 Answers
With SATA it will not matter which plug you use first or last. They will be recognized by the system no matter what.
I hope this helps your issue.
Thanks for using FixYa
asnowman
Posted on Sep 23, 2009
What are the specification of PS4 HDD?
  1. There are some of the specifications that you can look for to get a Hard Disk Drive is as follows -
  • 2.5-inch form factor.
  • 9.5mm thick or less.
  • Interfaced with Serial ATA (SATA) only.
  • Hard drive's type doesn't matter.
  • Speed also doesn't matter.
You can also get the detailed knowledge on the specifications that you must follow and other details through one of the best site that I've been using since last year to get all the details on latest updates, and many more from PS4 hard drive.
Oct 14, 2016 | Sony PlayStation 4
Foxconn 761mx
I'm going to presume that you have a tower or case that is the correct size.
First clean out the case of any junk, dust, etc. Then ground yourself to the case so as to dissipate any static electricity. I suggest you get a static clip for this.
Remove the motherboard from the static free film bag and locate the screw set bag. Most of the screws for ATX and Micro-ATX boards are standardized so it really doesn't matter which screws you use out of the bag. The vast majority of them should have a multi-head (phillips, flat, hex). Take the motherboard and gently place it in the case, making sure the case is on it's "back" so that the side you're mounting the motherboard to is flat on the ground.
Align the screw holes of the motherboard with the best fit of the screw holes found on the case. Note: If it is an intel based processor motherboard, you may need to mount the processor first and then the heat sync and fan before mounting it to the case, as it mounts directly to the motherboard. Since the Foxconn 761mx is an AMD board, this shouldn't be an issue.
Then locate your peripheral components (hard drive, optical drive, fans, heat sync, processor, ram, case fans, video card etc). Mount the AMD processor into the AM2 socket, making sure the socket handle is up or in the unlocked position. Once it is seated lock the processor into the socket by placing the handle down. Be firm but gentle in pushing the arm down. It should lock in smoothly, if you feel any major resistance, stop, release the handle and check to make sure the processor is in place correctly.
Once the processor is installed, cover the base of your heat sync with heat gel (Thermal Compound)(if it doesn't already have it, I suggest Arctic Silver~ http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007~ as it is superior than most of the preloaded gels).
Because this is an AM2 socket with a specialized clip, you'll find that it can be a little persnickety getting it on. The heat sync you have should tell you how to do it. If I remember correctly this particular clip you unscrew and loosen the side clips. The heat sync fits under this type and you then clamp it down. But I'm going off of a picture so I'm not exactly sure.
Once the heat sync is mounted and pressed firmly against your processor you're ready to situate your other components. Install your ram (making sure to match the notches to the spacer. This motherboard uses DDR2 ram so it's not that fast, but you have two slots to fill up to a max of 16 gb). Place your hard drives or SSDs into the drive bay where you'd like them to be, and place the optical drive into the optical drive bay. If you're going to install a zip drive or floppy drive (first why?) connect it to the black IDE connector. The primary hard drive on this motherboard can be either SATA or IDE. You can get SATA to IDE adapters if you need to have more than one SATA hard drive, or you can purchase a PCI-E SATA controller to expand the hard drive space.
Mount your video card in the PCI-Express X16 slot (the long yellow slot) and then mount your power supply in the specified space in the case. Finally mount your case fans. Usually one in the back below the power supply (if it's an upright case) and one in the front near the hard drive bay.
The power supply will have four screws (probably already in the case) that will hold it into place.
Now that all of your components are seated or mounted, it's time to connect the power supply to the components.
First locate the ATX power lead. This is pretty self explanatory. This will either be 12 by 2 or 8 by 2+ 2 by 2, or 12 by 2+2 by 2 connector that fits the main power connector on the motherboard, located next to the two ram slots. You'll find a 2 by 2 power port next to the processor slot. Seat both power power connections on the board.
On this board there are two power input only. The remainder of the power output goes to the hard drives or ssd, the optical drive, fans and heat sync, and possibly video card or other expansion cards. If you've installed legacy equipment (non-sata or IDE hardware) you'll have a large white four prong male plug that will fit tightly into a four prong female plug on the legacy equipment.
Where as if you're working purely with SATA devices, you'll have a flat power supply plug that is keyed (looks like an L) that fits into the smaller power supply plug found most often to the left of the main SATA port on the hardware. This plug will be larger than the SATA plug in width, but thinner in height.
The IDE port and 10 pin IDE port for the legacy hard drive and floppy drive on this motherboard sit next to the main power plug, while the SATA ports are the Two Blue L shaped plugs. The IDE port is blue while the 10 pin IDE port (for the floppy) is black with a lower left hand missing pin (keyed).
Connect your hardware to their respective ports.
Next locate the 8 pin plugs for the Case USB ports labeled USB1 and USB2, usually for the front. Most cases come with a front USB expansion port. This will attach to one of the 8 pin connection points on the motherboard. Some older cases come with firewire or extra usb expansion cables which can be attached to either USB pin plug. USB1 and USB2 ports are painted green on the motherboard.
You'll find on this motherboard four more plugs, one that looks like a very small black four pin port near your cmos battery, a four pin port that has no plastic around it labeled COM2 with a blue underlay painted on the board. A black painted 7 pin plug near the 4 pin black port and then another 4 pin plug point labeled speaker.
If you want to have a case speaker installed for use with beep codes (a set of CMOS codes that will beep if there is hardware failure) plug the speaker into this port (note: most new cases don't come with this speaker and to acquire one you should check with any second hand computer repair company). The 7 pin black pin plug is where you connect your power and reset button and power on light. The 4 pin port near the Cmos battery is for audio exchange. While most new SATA optical drives run audio through the SATA controller some legacy optical drives that are IDE need to be connected to the onboard audio using a 4 pin cable. COM2 is rarely used, but can be used for other controls, it works as a port extension. Many new motherboards don't have these because everything has gone USB and the old serial port standard isn't used anymore.
That is a complete guide to putting together your computer.
Oct 13, 2013 | Computers & Internet
Connections to the hard drive
The Harddrive is a SATA unit.
Uses a SATA data cable, and a SATA power cable.
SATA data cable, and connector on motherboard, example;
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Between the SATA data cable connector, and the SATA power cable connector; the SATA data cable connector is the shorter of the two in width.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
The connector end used on the harddrive side, and optical drive side, (CD/DVD drive), is usually a 90 degree Bent Elbow.
The connector end that plugs into the motherboard, is a Straight connector.
NOTE* Color of connectors does NOT matter.
Most of the time the SATA data connectors on the motherboard, are different colors.
This is to help discern what number of SATA data connector it is.
Four SATA data connectors on the motherboard?
SATA 1, SATA 2, SATA 3, and SATA 4;
Or:
SATA 0, SATA 1, SATA 2, and SATA 3?
SATA 0, or SATA 1, is usually reserved for the Harddrive.
The Primary harddrive with the Operating System on it.
(Unless you have harddrives set in a RAID configuration)
DOES NOT MATTER WHAT SATA DATA CONNECTOR, you plug into, on the motherboard.
Want to plug the harddrive into SATA 3, or SATA 4?
Go ahead.
NO matter what SATA connector on the motherboard that you plug into, BIOS will find the harddrive.
Note the L-shape in the connector.
Has to line up on the L-shape on the harddrive, optical drive, or motherboard, SATA data connector.
There is usually a lock on the connector. This you may not see.
Sometimes there is a little 'bump' on the connector. Depress with the thumbnail to install the cable, or remove.
This is an example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF, your SATA harddrive has a provision for plugging in a SATA power cable, AND a 4-pin Peripheral power cable; ONLY plug the SATA power cable in.
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Using BOTH types of power cables will BURN the harddrive up.
May not happen right away, but I assure you it will happen.
For additional questions please post in a Comment.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/SATA
Dec 10, 2012 | Acer Aspire X1 AX1470-UR11P Desktop PC...
Dell t3400 power for 2 hard drives
Not a problem.
This is a general view of a SATA -> data cable, and it's respective connector on the motherboard,
Note the L-shaped opening in the SATA data cable's connector, and matching L-shape on the SATA data connector on the motherboard.
Note also that a SATA data cable's connector has 7-pins
Between it, and a SATA power cable connector, the SATA data cable connector is the smaller of the two.
A SATA power cable has 15-pins,
Note that it's cable connector opening is also L-shaped.
So is the matching connector on a SATA harddrive, or SATA optical drive. (CD/DVD drive)
A SATA power cable's connector generally has an area on it, that you depress with your thumbnail, and this releases a Lock.
Depress to install, depress to remove.
SATA data cable connector, Or SATA power cable connector; that goes to a Harddrive, or to an Optical Drive, is usually a 90 degree bent elbow.
The straight connector on the cable plugs into the motherboard.
(Can be straight connector on both ends through, but isn't CORRECT)
SATA connectors on motherboard;
IF, this Ebay link selling a Dell Precision T3400 Desktop PC motherboard, is correct, there are;
http://www.ebay.com/itm/Dell-TP412-Precision-Workstation-T3400-Socket-775-Motherboard-/360503300257?pt=Motherboards&hash=item53efabd0a1
1) FOUR Black SATA connectors
2) ONE White SATA connector
3) One Blue SATA connector
1 Black SATA connector, and 1 Blue SATA connector, at the bottom of the black Ram Memory slots.
1 White SATA connector, and 3 Black SATA connectors, right next to the where 24-pin ATX main power cable, plugs into the motherboard.
General example of said main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Note* Color of connectors does Not matter )
Originally the Master harddrive, should plug into SATA1 connector on the motherboard.
If you look real close, next to all of those SATA connectors on the motherboard, you may see SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5, printed right next to them on the motherboard.
The beauty of SATA:
DOESN'T MATTER WHERE YOU PLUG IN WHAT, on those SATA connectors.
Use ANY one you wish, and plug whatever SATA device into it, that you wish.
BIOS will find the SATA device.
No matter what SATA connector you plug into, and no matter what SATA device.
Kapish?
http://support.dell.com/support/edocs/systems/wst3400/en/ug/ug_en.pdf
What a minute, this news just came in.............
The Blue SATA connector on the motherboard, under the black Ram Memory slots, is SATA0.
The Black SATA connector next to it is SATA1.
If you have SAS harddrives (Serial Attached SCSI), the power cable's connector has a provision, to plug the SATA data cable into it also.
If you do not have that particular SAS power cable it's OK.
You can just use a separate SATA power cable, (90 degree elbow to harddrive/optical drive), and a separate SATA data cable.
For additional questions, or to have me clarify further on anything I have stated above, post in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Dell Computers & Internet
Need wiring diagram for a hp m7680n
The good thing about the power connectors is they only fit where are supposed to fit. Either they do or the don't. There may be only three that are special. A 24 pin motherboard, a 4 (2x2) or 8 pin supplementary, and a flat 4 pin for a floppy drive. The rest are for SATA drives and the numbers really don't matter. Plus spares for possible expansion.
This is the manual.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748726&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3230688#N326
Oct 13, 2012 | HP Pavilion Media Center TV m7680n PC PC...
I replaced my power supply and don't remember where the connections went
Not too much way you can go wrong. There's a 20 or 24-pin connector which plugs into the motherboard in only one place. There probably is a 4-pin connector and that, too, goes into the motherboard (in a socket near the CPU). The other connectors are power connectors for you hard drive and CD/DVD. That's about it.
Oct 09, 2011 | HEWLETT-PACKARD Compaq Presario SR5518F...
Recently changed the power supply. There is no video output. Where can I download the motherboard schematic?
Right here at HP Support,
1) Motherboard Specifications:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00361570&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=459491
Scroll the page down to the top view illustration, and photo.
A) The motherboard uses a 24-pin ATX main power cable.
In the illustration the connector on the motherboard is on the right side.
It is an empty rectangular box with ATX Power Connector in it.
On the motherboard photo it is the rectangular white connector with two rows of 10 socket holes, and is to the bottom right of ram memory slot 2.
Another example of a 24-pin ATX main power cable,
Ensure that the 24-pin ATX main power cable's connector, is locked into place on the motherboard's connector. The lock tab on the main power cable must be hooked over the tab on the motherboard connector. This ensures that the main power cable is in all the way.
B) The motherboard uses a 4-pin ATX +12 Volt power cable.
The connector on the motherboard is a white square connector, with 4 socket holes.
In the illustration it is to the bottom left corner of the Processor socket (LGA 775), and has ATX12V underneath it. This power cable's connector also has a lock tab.
Another example of a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power TO the motherboard, that's it.
Power FROM the motherboard:
C) System Fan, and CPU (Processor) Fan.
Abbreviated as SYS_FAN, and CPU_FAN to the bottom left of the ATX12V connector.
(4-pin ATX +12 Volt connector on the motherboard)
The System Fan is the computer case fan.
CPU Fan is the Processor fan.
D) The four SATA headers on the bottom right in the photo, (Blue, Orange, Black, and White), are for the SATA data cables.
They connect to a SATA harddrive, or SATA optical drive. (CD/DVD drive)
(They are an L shaped connector inside, with 7 pins inside)
Power for these SATA devices comes from the Power Supply.
The Power Supply has SATA power cables.
Example of an average SATA power cable,
(L shaped connector with 15 pins inside. The longer connector between a SATA data cable, and a SATA power cable )
Did you forget which SATA data cable plugs into where, on the motherboard?
Don't sweat it.
The beauty of SATA is that you can plug the harddrive's SATA data cable into ANY of the SATA headers (Connectors) on the motherboard, and BIOS will find it.
Same with a SATA optical drive, or any SATA device, for that matter.
IF, your SATA harddrive has a place on the back for BOTH, a SATA power cable, and a 4-pin standard Peripheral power cable, ONLY use the SATA power cable.
Using both will eventually burn out the SATA harddrive!
Example of a 4-pin standard Peripheral power cable, (Misnomered as 'Molex'),
From there the main optical drive, (CD/DVD drive), has to have the audio cable plugged into the audio connector on the motherboard.
(Plus the power cable, and data cable, of course)
In the illustration this is the header down in the very far left corner, and located towards the bottom edge.
It has CD_IN marked underneath it.
In the photo it is the Black rectangular connector in the very far left corner.
If you didn't connect the 4-pin +12 Volt power cable, your Processor isn't getting any power.
No Processor operating, No computer.
No Signal on monitor.
(No video signal)
Regards,
joecoolvette
Jul 24, 2011 | HP Compaq Presario SR1430NX (PS566AA) PC...
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
Installed new power supply on hp m470n cannot remember which wires go where HELP
The large power connector goes onto your motherboard--20 or 24 pin--in the socket provided. It can only go in one way.
There is probably a second connector, a 4-pin--that will plug into the motherboard near the CPU. It, too, can go in only one way.
Other than that, you just have to hook up the power to the hard drive and CD/DVD.
If you have a high-performance video card that has a power connection, it's probably a 6-pin connector.
var fctb_tool=null; function FCTB_Init_1fa6d7a6c9664247a0ca49a75c796f65(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_8ff702f2dff743098e4136310439f4e3(t) { fctb_tool=t; start(fctb_tool); }
Nov 13, 2010 | HP Computers & Internet
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Sony VAIO RA820G (VGCRA820G) PC Desktop Logo
158 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
