Question about RCA P50830BL 50" Rear Projection Television
RCA 50" - Convergence problem and now "Popping" + no picture
We have a 11 yr old RC P50830 that worked fine until a couple of years ago when the convergence went on it. Had it repaired but then went again a couple of weeks ago. Tried to turn it on the other day and there was no picture but there was no a high pitch "popping" like a machine gun coming from the bottom right area of the box. Any idea what's wrong and how expensive it might be to repair? Maybe it's not even worth repairing with the cost of tv's these days? Any advice would be most helpful! Thanks!!
    President:
  • 788 Answers
The high pitch popping that you are hearing is arcing in the high voltage circuit. I would not suggest a repair on a set that is this old. Convergence repair plus a high voltage problem could run around $500-$600. But it is your call on the repair, I can only advise.
I hope this helps you.
Thanks for using FixYa
asnowman
Posted on Sep 23, 2009
I HAVE A 11 YR OLD PROJECTION TV 52"RCA EVERYTHIN OK BUT THE PICTURE COLOR IS SEPERATED AND LOOKS LIKE A CURVE
You have bad convergence ICs. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Mar 31, 2010 | RCA D52W19 52" Rear Projection Television
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
RCA 52" Projection HDTV Model# R52WH74YX60
I WAS TOLD BY 2 TV SERVICE TECH THAT IT IS THE CONVERGENCE BOARD MY TV IS DOING THE SAME THING I HAVE ORDER THE PART TO FIND OUT IF THEY ARE CORRECT.
Sep 04, 2009 | RCA HD50LPW175 50" HDTV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Hitachi 60" rear projection, convergence
Check out this document to adjust your Hitachi projection t.v. I did my 11 year old t.v. today.
Hitachi_DCAM_Manual.pdf
Jul 25, 2008 | Hitachi 50UX57B 50" Rear Projection...
LAGE PIXEL RECTABGLES PINK LIGHT AND BROCKEN IMAGES
Most likely a digital processing error, since it happens on multiple inputs. Service Time.
Shouldn't happen on a <2 Yr old component.
Feb 15, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Shadows on Rear Projection TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Televison & Video
Toshiba 50h81 turn it self off then back on
Did you check the supply fuses to the convergence ICs? Did you check the output resistors
then i would start by replace the convergence ic first.
Dec 01, 2007 | Toshiba 50H81 50" Rear Projection...
Wavy lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
TV picture shaking!!!
It sounds like the Hyper board is begining to fail....Does the menu shake too?
May 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
