Question about PUR (FM-9500) Air Purifier
Put new filter in....red light still stays on after 10minutes ofrunning water
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
Have a red light on in front - looks like something needs serviced. I rinsed the filters that pull out and light stays on. Might be a filter further in the unit or something might need to be reset??? ...
To the left of the little red light is the reset button. It's disguised as another light that isn't on. :) Press and hold it for about 10 seconds and the red light will turn off.
Mar 03, 2010 | Honeywell QuietClean HFD-110 Air Purifier
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Water filter
electronic circuit needs repair
Jun 01, 2008 | PUR (FM-9500) Air Purifier
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Oct 13, 2007 | Filter Queen Defender Air Purifier
Red light on air filter
After spending hours searching for this supposed little hole easy to miss, I called customer service. I found out that it's easy to miss because it doesn't exist!
Here's the correct answer: Once you've replaced the filters, turn the unit back on. Then, with the machine running, press and hold down the on/off power button for about two seconds. The red light will flash and then turn off.
Oct 12, 2007 | Holmes Products HAP422-UC Air Purifier
Hepa filter
The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
Red light won't stay off
I do apologize for the inconvenience, the best way that i can tell you to fix the light is that there is a tiny pin hole on top of the unit. that's a reset button. you need a small needle or something that will fit in there. hold it down for about 3 seconds. your unit should reset. the light sometimes comes on with new filters cause it hasn't recognized that they are new yet. if that reset doens't work please let me know
Aug 17, 2007 | Bionaire BAP825-U Air Purifier
Red light
Here is the link to the user manual; http://www.filterqueen.com/pdf/defender.pdf The red light indicates a filter needs replacing, see page 6 of the manual (page 9 of the pdf file) If filters have been replaced and the light still flashes, then the reset procedure (described on the same page) should work. If still flashing then there is a more serious, but probably fixable fault. Hope this helps - ask again if you need more info :)
Apr 13, 2007 | Filter Queen Defender Air Purifier
PUR (FM-9500) Air Purifier Logo
620 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
