Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
My endura 30 lower unit was filled with water and mud/rust. It was working all speeds before I opened it up. I had to hit the lower unit sometimes to get it to spin. The armature contacts have many pits, grooves and are missing some copper/brass finish in places. Is it worth repairing?
  • 76 Answers
You *may* be able to save the armature (about $45) by using some fine emory cloth to buff it back to life.
The brushes, seal kit, bearing, etc are about a $35-$40 bill. To have it done in-shop would be approx. $80 with labour.
Here's a schematic:
Endura 30
Good luck in your repair!
Mike
Posted on Sep 26, 2009
Compressor wont build air pressure only to 40 lbs
Have you checked the regulator setting? If you tighten the regulator down to the lowest setting and let it set for 30 minutes this may well re seat the valve face. So 1. Tighten the regulator to as tight as you can NO TOOLS just by hand. Let the unit set for 30 minutes. Unccrew the regulator know to the highest value. 2. Fire up the unit and test.
You may be joyously surprised. Otherwise it's likely a leak that only opens above 40 psi. If that is the case then you can let the unit run to load at 40 psi. Then with 1/4 cup of dawn dish detergent and 1/2 cup of warm water mixed together. Disconnect the unit from power. Mix the soap and water then pour over the joints of the unit and the drain spigot. The Drain spigot can sometimes become blocked partially open when a flake of rust becomes lodged at the valve face after draining. If so you will find the leak when the soap hit the spigot. Lots of bubbles indicated leak.
Hope this helps. I have seen issues at the reed valve on the compressor where one or two of the screws that hold the reed valve to the cylinder head beome loose.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/john_28069c9efb56199d
Nov 09, 2013 | Ridgid OF50150TS Pressure Switch
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
My motor runs smooth and quiet when out of the water. It runs rough (jerky) and noisy when in the water. Runs this way at all speeds and with handle extended or retracted.
is the propeller tips broken off or fins missing pieces. the propeller will become unbalanced. if the propeller is ok then the bearings are going out in the drive motor
Oct 28, 2009 | Minn Kota Endura 30 Freshwater Transom...
I dumped my 99 yz125 in a mud hole. It won't START
try cleaning your carb out and make sure the magneato is not rusted
Aug 01, 2009 | Yamaha YZ 125 Motorcycles
MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
Hi!
Here is a schematic for your motor:
Endura 30
It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
Best of luck!
Mike
Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
I need a truster speed for a Minn Kota Endura 46
Hi!
Here is a scchematic with part numbers and service center listing as well:
Endura 46
Best of luck!
Mike
Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
MinnKota Endura 50 Runs only in high speed in forward and reverse
the coil pack is likely bad especially since you changed the switch. call minkota and get the bench tast info (very simple) and then order and replace the coil pack about 26 dollars. be very careful how you put the magnet assembly back together and mark the position of the case on the outside before disassembly. order a new seal kit and use locktite on the shaft again when reassemling to seal the shaft tube for water. dont run motor uout of the water much as it uses the water to cool the shaft and you can damage the seals. good luck.
Jun 18, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn kota endura 30 repair
The top section will pop off when the six screws are removed. It might just be dirty and sticking.
Apr 12, 2009 | Minn Kota Endura 30 Freshwater Transom...
Water will only trickle to fill ip washer. Is it
Most likely its the inlet hose or hose screen.
If water pressure is standard at all other areas in home secure 4 Hose washers at any lowes ace hardware or garden supply that sells garden hoses. Remove your hoses and place the ends in the basket and turn on the water. If you get a good flow out then look at the water valve inlet behind the washer. If its clean put on the new washers and retry it. Be sure to run the valve wide open a couple of times to flush out any mud or sediment before deciding the inlet is clear. sometimes the old galvanized pipes can be plugged up with rust. If the water is trickeling in and it is suppose to be on then it is not the solonid valve because its trickeling in not flowing. Let me know if this trick works and \please ratem me as high as you can. Thanks for using FIXYA and good luck.
Apr 06, 2009 | Washing Machines
Machine is not filling with water.
hi
the solution is so simple, you have to open it
and clean the plastic pipe that runs from the tub to the load switch, sometimes gets dirty with detergentes and mud.
Mar 07, 2009 | GE Profile WPRE6100G Top Load Washer
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
724 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
