Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
We have broken the cold water button off. How/where can I get a new part?
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
Jun 15, 2014 | Water Heaters
Heating coils were replaced last december and today no hot water for a shower after 5 minutes in the shower. The electric is flying on the meter. Have shut off the circuit breaker for this hot water
Copy following link for tank-type electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Press reset button located on upper thermostat.
Test elements for short to ground against steel tank.
Clean sediment out of tank. Check for water leak running hot water out of tank.
Replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 25, 2012 | Rheem Water Heaters
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Aug 27, 2012 | Refrigerators
30 galons gas direct fired water heater.\r\nI get hot water for 2 minutes, then water gets cold
The dip tube on the cold water side either is not there or it is broken off then the cold water stays on the top and gives cold water quickly...
If this is a new installation then check that the piping is correct and that the cold and hot pipes are not switched...
heatman101
Feb 02, 2011 | General Electric Water Heaters
We have both hot and cold hoses going into washing machine but cannot get anything but cold or lukewarm water no matter what setting we choose. The pipe leading into the hot water hose feels warm and we...
sounds like the mix valve on the washer is broken and not opening properly -- the mix valve is the valve that both hot and cold water are connected to on the back of the machine.. turn off water valves and remove the hoses,, remove the back panel from the washer -- the mixer is held in place by one little screw,, also mark the wires going to the mixer ( hot/cold ) --- remove the mixer valve and take it down to your local appliance repair shop and match it up to a new one -- install the new mixer and connect wires and panel and then hoses and all will be working good as new.
c...
Feb 01, 2011 | Hotpoint Washing Machines
Water starts of hot but then starts to get cold.
You need to verify that you still have hot water. Sounds like you're running out.
Sep 28, 2010 | Home
The water coming out of my faucets, washing machine, shower, etc. is not getting hot.
Your heater is on? Do you regularly drain off sediment?
Have you contunity tested your elements (power off)? Volt tested the same (power on)?
Has anyone fooled with the thermostat?
There is the possibility the dip tube (cold water going in) has broken off and instead of sending the cold water to the bottom, the cold goes straight from the cold water entrance pipe to the hot water exit pipe. Normally, one would expect cold water to sink and hot water to be on the top but, when you are drawing water off the top, with a broken dip tube, the water travels the shortest distance required, thus, your luke warm water.
I hope you can find your trouble by following one of these hints.
Thanks
a
Oct 18, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
No hot water filling washer
Check to see if there is a filter located in the valve, remove and clean.
If still no hot water then disconnect hose and make sure you have actually got water at valve, if you have and it still does not come in, and you can hear a buzzing noise, then I would say that it is sticking and you have a faulty inlet valve, only solution is to replace said valve.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Washing Machines
Water drip into washer, used to gush in. Now water pipes bang, whine
The problem is the 10 cent rubber washer in a shut off valve in your plumbing. The brass screw that holds this washer has corroded and the washer has come loose. It now floats around inside the valve and the water flow can be blocked at one time, whistle, howel and make bangs at another. It could be any valve including the main shut off. You can listen to the pipes but the sound travels, so you are looking for the loudest spot. A new washer and screw could fix it, but sometimes the screw is broken off requiring a new valve stem. Be prepared to replace the whole valve.
Oct 31, 2007 | Maytag Washing Machines
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
46 people viewed this question
Top Whynter Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
