Question about Apple iPhone 3G
Glass facing is cracked - Apple iPhone 3G
  • Apple Master
  • 4,338 Answers
If it is out of warranty, you will need to purchase a new Digitizer and replace it. Here is a link that show how to take apart.
http://www.formymobile.co.uk/iphonedisassembly.php
Posted on Sep 23, 2009
Is it easy to replace a cracked screen on a acer iconia B1-710?
I've done several Samsungs, a couple of Apples and a Nextbook. I've never done an Acer but I'm guessing it's not too difficult.
Look up YouTube videos on the subject. You can probably find one for the exact device you have.
If the image on your tablet still looks perfect but the glass in front of it is cracked, then you only have to replace the digitizer glass. The screen is behind that. If you have to replace both, try to purchase an assembled package because it will be easier.
Typically, the image screen is fastened to the tablet frame with double-faced tape around the edges. Then another layer of double-faced tape goes around the perimeter of the image screen and the digitizer is stuck onto that. Getting things apart involves using a hair dryer and several little plastic pry tools (some of which look like pry-bars with a handle and some of which look like guitar picks) to separate the glass parts from the heat softened adhesive. I've found that having several single-edge razor blades is also handy as long as you don't slip and push it into your finger.
When you replace the adhesive between the screen glass and the digitizer glass, make sure you don't leave any gaps in the adhesive. Pressing on the front digitizer glass oil-cans it in and out and if you leave any gaps in the adhesive, dust will get sucked in between the sheets of glass.
By the way, I will NEVER do a Nextbook again--at least I wouldn't replace just the glass. They don't use double-faced tape at the factory. The glass was somehow bonded directly to an aluminum frame. Much of the glass I scraped off the frame only came off when pulverized into powder. I would buy the replacement glass already bonded to the aluminum and just snap that on. Probably wouldn't be cheap.
Feb 28, 2015 | Acer Tablets & eReaders
FACE IS CRACKED
If you have a glass face on your watch then you will probably need to get it replaced. If the face on your watch is plastic then you might be able to get it buffed and possibly smoothed out.
Mar 07, 2011 | Citizen Watches
Cracked mirror only, mounting and other parts are functioning well. Can I purchase a mirror only and if so, where?? This is for 2006 Pontiac Grand Prix and the passenger side mirror is cracked but works...
Hello, yes the glass can be replaced. you will need to see your local GM dealer for the glass. real simple to replace.
  • Carefully push the outside rearview mirror face on the inner edge, near the front door window glass, to allow access.
  • Insert a large flat-bladed screwdriver in the slot between mirror lens and the mounting base.
  • Grasp the mirror face firmly and pull it from the mirror body.
  • Remove the outside rearview mirror case from the outside rearview mirror housing and disconnect the heater wire, if equipped.
  • Using the palm of your gloved hand, press firmly on the center of the glass until the case seats onto the motor.
  • The mirror will make a snapping noise when properly seated.
  • Inspect the mirror for proper operation.
    Jul 03, 2010 | 2006 Pontiac Grand Prix
    The glass face has cracked diametrically from side to side
    mcdevito75 here, If it is a crack and not just a scratch almost ant watch repair shop could replace the crystal (glass) a crack means replacement and a scratch might be able to be buffed out, Expect to spend $30.00----$60.00 either way.
    Jun 22, 2010 | Skagen 355LGSC Wrist Watch
    We have a crack in the face glass. can this be repaired. the watch is less than 12 months old. Crack runs from 11 o'clock down to 3 o'clck. Don't know how it happened as it hasn't been dropped.
    A face glass can be replaced.
    Take it to your nearest what shop and discuss it with them.
    It may be that it will have to be sent to the maker if it is an unusual shape or size. If this is so, the watch shop should be able to sort it out for you.
    Feb 19, 2010 | Watches
    Glass that covers the face of the watch is shattered-$ to replace
    I am not sure about prices in US, but over here in England we charge £15 - £25 for mineral glass (depending on size, thickness, e.t.c.) and £50 - £120 for sapphire glass. As for today: £1 = 1.60$. Doesn't matter how you name it - glass or crystal, both are right.
    Jan 11, 2010 | Bulova Watch
    Iphone face cracked
    Here is an iPhone Repair Guide that shows how to open an iphone. a and replace the glass. Once it is open it's as easy as prying the old glass off the front assembly and installing a new one, the parts are available on ebay.
    Mar 15, 2009 | Apple iPhone 3G Black Smartphone
    Crack face glass
    good after noon ! if you want to repair your watch can you bring here in my own watch center ,the exact address is ,MEDRANO WATCH and CELLPHONE CENTER located at b.laqui st.brgy.3 cuenca batangas philippines,thank you ! GOD BLESS !
    Aug 28, 2008 | Skagen 105LTMXB Wrist Watch
    Cracked glass on face plate
    ebay, they are around $15, just be careful prying it off. You might have to take the top cover off to remove the glass. To put the new glass on close it all up first, then stick the new glass on. good luck
    Nov 24, 2007 | Motorola Mobility RAZR V3
    Apple iPhone 3G Logo
    Top Apple Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Lesley Cameron
    Lesley Cameron
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
