Question about Sanyo VPC-E760 Digital Camera
MY LENS ON MY CAMERA WILL NOT GO IN AND THE CAMERA WILL NOT STAY ON
    Sergeant:
  • 151 Answers
For this problem try the following:
* Try removing the memory card and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
Hope this will help
Thanks
Byron
Posted on Sep 23, 2009
    Problem Solver:
  • 18 Answers
Try using lithium batteries they may be pricey but they should fix the problem -rrj182
Why won't my camera lense stay open
Its the power saving feature that retracts lens if camera not used for a set length of time.
If you want camera lens to stay open longer, change the settings by assigning a longer period of time.
Aug 17, 2014 | Cameras
I have a Nikon N65 and an AF Nikkor lens on it. The lens fell off some time ago, and now it does not lock in place.
The most likely culprit is a broken mount on the lens. Some Nikkor lenses have a plastic mount whose bayonet blades can break off when the camera is subjected to a shock. Since you neglected to specify the lens I don't know if this is the case with yours.
If you have access to another lens, try it. If that one stays on then the problem is with your lens. If that one doesn't stay on then the problem is most likely the mount on the camera itself, which is a more serious problem (unless the mounts on both lenses are broken).
Jun 19, 2012 | Nikon N65 35mm SLR Camera
I have a NIKON DX AF-5 Snikkor 18-105mm lens 13'5-5'6 GED lens That will come off the camera after being attached. Another lens AF-S Nikkor 70-300mm stays on. I dropped camera from 2 ft...
It seems like you've got a broken lens mount on the 18-105mm. Take a look at the backs of the two lenses. You should see the bayonet mount with three flanges. If one or more of the flanges on the 18-105mm are broken then the lens won't stay on.
If you feel up to doing the replacement yourself, you can order the part from
http://uscamera.com/1c999-729.htm
Otherwise have a trained technician replace the mount.
Jun 30, 2011 | Nikon Cameras
Lens error
Hi.
Check the articles below and follow troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
Regards.
Apr 09, 2010 | Nikon Coolpix S210 Digital Camera
Kodak digital camera will not stay on. Lens retracts immediately.
Hi. I actually have the same EXACT problem. DId you end up fixing it. If so, how?
Mar 15, 2010 | Kodak Cameras
Casio Exlim Z6. Lens stay out when camera is
Please view my FixYa Tip on this subject for a complete walkthrough of the potential causes and solutions.
http://www.fixya.com/support/r3556007-camera_lens_stuck_or_wont_retract
Many thanks for using FixYa.
Dec 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
The lens wont retract(its stuck) thus the camera will not stay on when power button is pushed
FOLLOW this procidure open the camera then rotate the lens and set it like it was before
May 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
The lens is stuck
my daughter sat on ours while it was on and the lens wouldn't retract. I tried the banging repair suggested for a stuck lens. After quite a few tries, it got the lens to retract when turned off but it wouldn't stay out when on, so i grabbed the lens and gently pulled it all the way out while it was on and it worked! (phew!)
Sep 15, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Camera does not stay on
read manual on how to reset the camera...may be a small pinhole...
Jun 01, 2007 | HP Photosmart M527 Digital Camera
Camera won't stay on; date/time won't stay set
Are you sure the lens is actually going all the way out? If there is debris in the zoom gearing it can cause the lens to stop extending which would in turn cause the camera to re-retract the lens and show an error. Other possible explanations are that the sensor which determines when the lens has reached full extension has failed, so the camera keeps extending the lens until it reaches the physical limit - and then behaves just as if there was a jam as described above. The fact that this occurs both when you power on and power off the camera leads me to think this may be the case. The loss of date and time settings is due to a dead backup battery. Check your manual to see if this is replaceable by you or if it requires disassembly. David Millier Advance Camera Repair
Feb 17, 2007 | Nikon Coolpix 4300 Digital Camera
Sanyo VPC-E760 Digital Camera Logo
59 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
