Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do i conect the low volt wire ( the safty eye and the button wire)?
    President:
  • 3,197 Answers
The terminals on the rear of the motor unit are both numbered and color coded. The white wire with the red stripe from the wall control goes to terminal 1. The solid white wire goes to terminal 2. The 2 white wires with the black stripe from the sensors go to terminal 3 and the 2 solid white wires go to terminal 2. You should end up with 1 wire on terminal 1, 3 wires on terminal 2 and 2 wires on terminal 3.
Posted on Sep 23, 2009
H ow to replace timer with phot0 cell
Malibu ML300 has 120 volt input and 12 volt AC output
They make a photo eye for the timer... wiring is changed a bit... will work on ML300 if timer has A-B-C wiring terminals
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#wire
You can use a 120 -> 12 volt ac transformer that is rated for 300 watts... and connect in-line photoeye on the 120 volt side.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
http://waterheatertimer.org/Reverse-photo-eye-so-it-turns-on-at-daytime.html
Gene
Water Heater Timers Save Money
Jul 17, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
Landscape lighting transformer hums only when controlled thru photo-cell, and not when powered directly.
1) Copy following link for Intermatic/Malibu power pack photo-eye instructions, general troubleshoot, manuals, replacement trippers, and tips to prolong life of power pack:
2) Brand and model of transformer and photo eye are unknown.
Wiring changes are unknown.
Volt rating of photo eye is unknown.
Wiring of photo eye is unknown.
3) Add a comment including details, and attach photo, after reading information on link above, for live response Jan 2013
Jan 01, 2013 | Home
My pool heayer will not light
check wiring they come for 240 volts if connected 120 volts some wiring to be changed or conversion board to be flipped to 120 volts some have you change the wire on the fenwal to 120 volts
Dec 06, 2011 | Jandy Pool & Spa
I have an H250 NG and when I light the pilot it goes out when I release the pilot button on the gas valve?
The first thing That comes to mind is a bad pilot generator or thermopile. This makes a small half volt charge that energizes the magnets that open the two stages in the gas valve. Next would be a bad gas valve itself. You will need a milivolt meter to check both of these. Lastley is the safty circut. This is the string of switches that can shut the heater down if problems exist. Their are two sets of wires connected to the gas valve. One set goes down to the pilot, this is for the pilot generator. The other set is the safty circut. If you remove these wires and the pilot lightes and stays lit the problem is in the circut. Still no pilot then it is in the pilot or valve. Good luck.
May 28, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Need wiring diagram for eyes that control safty device door willnot close by one button push , have to hold button to close , light on opperator has one flash
Safety reversing sensors wire open (broken or disconnected).
Each sensor has a solid white wire and a white wire with black tracer.
The solid white wires go to terminal 2 and the wires with the black tracer go to terminal 3.
Jan 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
Replaced battery and starter now it wont even engage selonoid
You need to check your voltage to the starter with a Volt Meter. Check the battery cable to the starter, that should be 12.5+ or higher. If not, you have a bad cable connection. Clean it with a wire brush and make sure it makes good contact both positive and negative. If good voltage check your start voltage. Usually a Spade Connection on the starter. Check it with the spade hooked up to the starter. If no voltage, put your car in Neutral and try it. May have a bad neutral safety switch. Hope this helps.
Oct 10, 2009 | 1998 Oldsmobile LSS
Accidentally conected it to 220 volt outlet
Hi, damage should be limited to low voltage power supply, I would definitely have a tech take a look at it, video-tek
Jul 03, 2009 | Toshiba 50HDX82 50" Rear Projection...
HBW 0777 Liftmaster Garage Door Opener
steve it sounds like the two eyes are not lined up to communicate with one another and complete the circuit so the door will work. This is a safety feature. Begin by seeing if adjusting the eyes will line them up and tuen on both green lights. Also be sure the wire to each light is still connected.
Apr 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman zero turn model# 107.27774
If you are jumping the solenoid and it cranks but wont start leave the key in the on position and give it a try. Try replacing the solenoid and the wires conecting it to the battery.
Apr 24, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
150 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
