Question about HP LaserJet 4L Printer
HP laserjet 4L will not print from Windows Vista
Printer powers up and will successfully print a test page. It is connected to my Toshiba lap top via usb cable. Windows Vista recognizes hardware, but fails when I try to print. I have property settings set to "usb port" and "bidirectional" is checked (I have tried unchecking bidir. also). I have tried deleting the printer and re-installing, I have rebooted many times.
    President:
  • 1,126 Answers
Http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25486&taskId=115
Here is all the documentation that I could locate reguarding this issue. I don't see a driver for Vista....however you should be able to install or run in compatibility mode.
Posted on Sep 23, 2009
HP LaserJet 4L quit working It's connected to my PC and it's on. All 4 lights are on; 2 green and 2 orange. When I try to print, the paper goes through but nothing is printed on the paper.
Empty cartridge maybe?
Otherwise it's simple: selt-test page(by printer button) printed ok - it's outer problem. Self-page is blank - it's inner problem. And so on... use Golden Section method
Jan 10, 2014 | HP LaserJet 4L Printer
I've downloaded the Vista driver for a Laserjet 1160, go through the add printer process, it confirms printer added successfully, but it still won't print. I've checked leads and USB ports and the printer...
Sandra, Do you see the HP LaserJet 1160 printer listed in Start (Windows Icon) > Control Panel > "Hardware and Sound/Printers" (Control Panel Home), or "Printers" (Classic View)?If you do not see the printer listed, run the installation from the CD that came with the printer, or you can download the drivers from the HP support site at http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=410620&lang=en&cc=us&prodTypeId=18972&prodSeriesId=410618&taskId=135note: make sure you choose the correct version (either Windows Vista, or Windows Vista x64). If you're unsure, you can check by right clicking "My Computer" and selecting "Properties". Under the system category you will see "System Type" noting either a "32-bit operating system" or "64-bit operating system". If you do see the printer listed in control panel/printers, then: Are you able to successfully print a test page? (Right-click the HP LasterJet 1160 and select "Properties", then select "Print Test Page").If not, does the test page show up in the printer queue? (You can check the queue by simply double clicking the printer). Let me know what you find!- Joshua
Jun 08, 2009 | HP LaserJet 1160 Printer
HP laserjet 4L parallel to usb vista Jumbled font on test page
You mentioned parallel usb. The HP4L only has parallel. Make sure you specify LPT1 as the port you want. Try reinstalling the driver. It should be in the list of drivers.
Feb 21, 2009 | HP LaserJet 4L Printer
HP laserjet 4L wont print from computer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | HP LaserJet 4L Printer
reinstall the printer driver.
Windows operting system have the printer drivers. you don't need to download it.
if you really want to, goto HP.com>> service and support.
Oct 21, 2008 | HP LaserJet 4L Printer
Got a new computer - can't find 4L Drivers
HI,
You can get the drivers from www.hp.com just go to support page and then click on downloads.
Sep 12, 2008 | HP LaserJet 4L Printer
HP LaserJet 1320 problem
For this you first uninstall any previous Driver. Install the Drivers after restarting your system. After Installing the drivers connect the Printer. Note down now the Driver must be automatically work because HP1320 is a plug n play Printer. If not change the cable used to connect the PC with Printer and if the Printer is auto detected, you will be able to print the Test Page or any other page.
Feb 12, 2008 | HP LaserJet 1320 Printer
My HP LaserJet 6L Won't Print on new HP/Vista PC
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook
Connect both ends from pc to 6L printer
Go to website to choose the correct O/S driver for installation
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476
Use virtual USB port005 for printer 6L
Bi-directional option can be ticked
Click apply and ok
Unplug and replug the USB cable
Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
Jan 20, 2008 | HP LaserJet 6L Printer
HP LaserJet 4L Printer Logo
224 people viewed this question
Ben Johnson
