Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark Printer 8350
I bought a Photo Print Cartridge, and I am getting "right cartridge error, replace cartridge"
    Sergeant:
    Champion:
  • 317 Answers
Check if the printer's cartridge slot is not dirty or clogged with plastic or paper.
Posted on Dec 15, 2007
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
The Lexmark X6650 gives an error: Right cartridge incorrect. This is a new original cartridge I've just installed. The electronic part on the printer is clean and the electronic part on the cartridge...
  1. Remove the print cartridges, and close the cartridge carrier lids.
  2. Disconnect the power cord from the electrical outlet.
  3. Reconnect the power cord to the electrical outlet.
  4. If the button_power_0.jpg button is not lit, press button_power_0.jpg.
  5. Reinsert the print cartridges.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
  5. Reinsert the black (or photo) print cartridge.
  6. If the error:
    • Reappears, replace the black (or photo) print cartridge with a new one.
    • Does not reappear, reinsert the color print cartridge.
  7. If the error reappears, replace the color print cartridge with a new one.
Jul 22, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
I have a lexmark x8300 printer (all in one). in the past I have been successfully using refilled black no.32 and colour no.33 cartriges. However it used to say 'low ink replace cartridge' but it had always...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 21, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Unsupported cartridge
If this is a genuine Lexmark device and a genuine Lexmark cartridge and you followed all the install instructions, return it to where you bought it for a replacement. If you get grief there, contact Lexmark directly. Please have your receipt available when you take these actions.
thanks for your interest in FixYa.com
Jan 20, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
P315 print cartrige error
What we surmised is that the little wire contacts on the print cartridge were bad. One suggestion was to use a pencil eraser over the area where the small wire dots are on the cartridge, then wipe clean with a lint free cloth. That didn't work either so I exchanged the cartridge and the problem went away.
May 14, 2009 | Lexmark P315 InkJet Photo Printer
Incorrect right cartridge
Ive tried removing the right cartridge so I can print in black, but now , once I refilled the black one, it wont even let me print black!! this is desperate; can anyone help?
Aug 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
LEXMARK 8350 - Right Printer Cartridge error
take cartridge out again and inspect carefully the circuit inside the printer where the cartride goes. Look for dust, dirt, ink etc. Try using a can of air to clean the area too. Not sure if it will be visible but look for a ribbon cable near the circuit area too that may be loose. You might want to take it to a local computer shop ( not a chain store like best buy etc ) often they can do a simple repair pretty cheap and fast. Good luck
Jul 31, 2008 | Lexmark X8350 All-In-One InkJet Printer
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
