I have a kenmore stackable washer/dryer unit model #41799375120. We use it upstairs for our two apartments. It has worked fine but last night we found a small puddle of water on the floor. It cycles fine, I can't see any water actually exiting anywhere....so what could it be and is it worth fixing? I checked the hoses and connections but no wetness or water
  • Washing Mach... Master
  • 15,950 Answers
It is the tub seal. There is a shaft that goes through the drum from the drive assembly. The seal is about 45 dollars. Installation is a different story. You can get the part at Sears and they can offer tips on replacing it. Basically you lay the unit on its back and be ready for the water that is still in the hoses and drum. Then take the agitator cap off and the associated hardware that is under the cap that holds the agitator on it. While you are there check the splines on the shaft and the nut assembly that is there. If they are work replace them. Then you go back to the bottom and remove the drive assembly and pull the shaft out of the drum. You then remove the seal and put in the new one. Be sure to use a vaseline grease on the new seal parts that contact the shaft. It is a good idea to use a seal installation tool to put the new on it. Then you should cover the shaft with a sleeve so that it wont score the seal when you put in back into the drum. Put the unit back together and run it once on high temp to remove any grease.
Posted on Sep 23, 2009
Replace Kenmore electric stackable washer and dryer model #41794702300
Frigidaire built that unit for Kenmore, so look at new Frigidaire stacked "Laundry Centers."
Aug 29, 2016 | Kenmore Dryers
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Sears Model 417 stackable washer and dryer
The model that you provide is incomplete. However, if the washer loads from the top, they cannot be separated. If it loads from the front, they can.
Apr 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Washing Machines Logo
Top Washing Machines Experts
