Question about Poulan Pro Chain Saw 46cc 20"
Its only 2 yrs old my poulan chain saw 18inch it quite oiling
  • dontbother10
    dontbother10 May 11, 2010
    We can provide a broad worth very little answer or you can provide the make, model number, and serial number from the manufacturer?s tag and get a much better answer. It also helps if we know whether American or European. These generic headings aren't trustworthy. If I provide an answer based on an incorrect make or model you won't be helped!
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: locate exploded drawing of poulan chain saw
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
  • 666 Answers
SOURCE: how to remove poulan chain saw oil check valve
I believe this saw has a duck bill valve that is removed by removing the star fastener that holds it in place. I normally use a pick type tool to pry the fastener up.
Posted on Apr 10, 2009
  • 154 Answers
SOURCE: not much oil on poulan chain saw bar
there is some debris blocking from entering the bar and when sits it seeps out,clean bar and are under chain cover
Posted on Aug 02, 2009
dontbother10
  • 2220 Answers
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Posted on Sep 05, 2009
Wild thing saw brand new used once, over heating, not wanting to cut, why?
If there is no oil getting to the chain, you will have metal to metal contact between the chain and the bar with no oil film, the chain will look dry and be covered in baked on resin from the heat, make sure you have adiquate chain oil in the oil chamber, this chamber is seperate to the fuel chamber, it should be filled with a non fling chain oil.
Aug 28, 2011 | Poulan P4018WT Wild Thing 18Inch 40cc...
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
Having trouble putting on new chain.have no manual.the 2 mounting holes in bar what are they for
There should be some bolts that allow you to tighten the bar, and a slot that allows the bar to slide when you loosen the bolts.
Also, there should be some kind of adjusting screw that allows you to tighten the chain. To remove the old chain and install the new chain, you'll need to completely back off any tension on the adjuster, allowing the bar to move TOWARD the chain saw.
You should keep the chain oiled, and whenever it stretches, even a little, you should adjust the chain according to the owners manual too keep it at the right tension.
The two mounting slots are usually aligned with something that will keep the chain bar straight; such as a bolt or perhaps a pin in the motor assembly.
Mar 13, 2011 | Poulan P4018WT Wild Thing 18Inch 40cc...
Motor runs well but chain wont move,l it only 3 months old what next?
Make sure that you can move the chain by hand and that it is being properly oiled. Remove the bar and chain after releasing the chain brake. Clean the side of the engine where the bar fits to, then start the engine--oil should ooze out of the port. Wash out the interior of the clutch with spray carburetor cleaner to clean away excess oil accumulation. Clean the drive end of the bar small oil passages that run from the large holes out to the chain groove on each edge. If oil oozed out during the run test, reassemble everything making sure the chain teeth cut toward you on the bottom run. Adjust the chain up to the bar, but not so tight that you can't move the chain by hand. Tighten the cover fasteners and recheck the chain tension. Start the engine and run the bar tip near some cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Dec 12, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I have an 18" Poulan chain saw, 25th Anniversary
Yes there is.If you can get the broken pieces out of the tank.there should be a filter on one of the broken lines.you will have too buy some gas line 3/16.take some wd-40 and spray the line.this makes it easier to slide through the hole in tank.then loop it around to gas cap hole and reinstall filter.then make sure filter is at bottom of tank and hook back to carb.
Nov 24, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
I have a poulan wind thing 18inch need Oregon chain replacment number or kind
Chain part number 952051338
and just in case:
Bark replacement number 952044418
Oct 14, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Not starting lacks compression,what's cylinder compression psi
as i tell everyone on this site a poulan saw is cheap **** buy an echo hope this helps
May 25, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
42 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
