Bought a second hand 1992 Ford Explorer Eddie Bauer Edition. Did not receive the manual with it. Does anyone know how to change the temperature for heater, etc.
Did you by chance check for DTC'S diagnostic trouble codes?
Instrument Cluster Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1255
Air Temperature External Sensor Circuit Open
Instrument cluster
Go To Pinpoint Test E .
B1257
Air Temperature External Sensor Circuit Short to Ground
Instrument cluster
B2097
Compass Module Failure
Instrument cluster
Go To Pinpoint Test B .
U2013
Compass Module - No Response
Instrument cluster
All Other DTCs
Instrument cluster
REFER to Section 419-10 .
Question edited for clarity, full year make model
Question moved to sub category.
It appears to have history. A bit worrying you say 'kinda changed the filter and fluid'. Most are sealed for life, and the amount of fluid is critical. If you drain, you measure what comes out and replace with the same amount of the right type of ATF.
I would be very proud of that truck as the sub that came with the truck was only a 8". The only one that works is the factory model as it is a 1 1/2 - 2 ohm speaker; replacements are 4ohm. You will have to replace the amp as well if you put in an aftermarket sub. Oh and apparently the amp will have to have "speaker level" inputs as opposed to pre-amp inputs. I have a 1999 Eddie Bauer wih a blown sub and I'm trying to decide what to do as well. The speaker is $400 with tax in Canada! Good luck.
