Question about HP LaserJet M1522n MultiFunction Printer
While trying to send a fax
Code 49 appears
  • 223 Answers
Try doing a nvram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print out a configuration report after resetting the printer to view the ip address (IPV4). If the IP address has changed you will need to update the print driver's port tab and update the port.
Al
Posted on Jul 28, 2010
4 Suggested Answers
  • 4 Answers
SOURCE: Cannot send fax
plz chek telephone line or fax roulers
Posted on Jul 01, 2009
  • 277 Answers
SOURCE: Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Posted on Mar 07, 2011
  • 12 Answers
SOURCE: We have a M2727 Laserjet
Error 49 is typically an issue with corrupted firmware on your device. Firmware is software that tells the actual hardware how to process things like prints and faxes.
Updating your firmware is pretty simple. First you need to download the firmware utility from HP for your printer. For your model, here it is:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-7&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=3
Then, follow the directions from HP to update the firmware:
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the M1522_MFP_Series_FW_Update-20100902.exe. An HP firmware update window will open.
  4. Select the appropriate MFP in the dialog window. If you assigned a different name to the HP MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. The flash firmware update process is complete.
  11. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100902.
Finally, give another fax a try!
My officejet 4500 keeps giving me an error code 350 when trying to send a fax. how do i fix this?
try to disable Error Correction Mode (ECM).
to do so:
Press Menu . Press the Right Arrow (>) until Advanced Fax Setup appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode appears. Press Enter . Press the Right Arrow (>) until Error Correction Mode ON or Error Correction Mode OFF appears. Press Enter . Send another fax to verify that the ECM is enabled or disabled.
Sep 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Remote fax error
- Resend the fax. There may have been a problem with the quality of the telephone line connection. - Try to lower the transmission speed.
  1. From the control panel, press Fax Mode.
  2. Press Menu.
  3. Press ? or ? repeatedly until Fax Setup appears.
  4. Press check.
  5. Press ? or ? repeatedly until Dialing and Sending appears.
  6. Press check.
  7. Press ? or ? repeatedly until Max Send Speed appears.
  8. Press check.
  9. Press ? or ? repeatedly until a lower speed appears.
  10. Press check.
  11. Select 9600 bps.
  12. Try to resend the fax.
You can also refer to the Lexmark 5400 Series User's Guide.
May 23, 2011 | Lexmark X5470 All-In-One InkJet Printer
We have a M2727 Laserjet Printer/Fax . We can print, and we can receive fax, but our problem is sending a FAX.. Keeps giving us an error code of 49. Please advise Thank-You, Marla
I found this on the HP website:
HP LaserJet M2727 Multifunction Printer Series - 49 Error Message Is Displayed While Faxing ISSUE: The printer control panel will be displaying 49 service error while sending faxes. The receiving fax will be lost, and the printer will display the same error even after reboot. SOLUTION: Performing a factory reset and a firmware upgrade is the only solution for this issue. Step 1: Performing a factory reset Restoring the factory-set defaults returns all of the settings to the factory defaults, and it also clears the fax header name and phone number. CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the product. Perform the following steps to restore the factory-set defaults: 1. On the product control panel, press Setup . 2. Use the arrow buttons to select Service , and then press OK . 3. Use the arrow buttons to select Restore defaults , and then press OK . The product automatically restarts. Step 2: Firmware upgrade After coming to ready, upgrade the printer firmware from the HP website. The issue can be fixed with any of the firmware upgrade available now. Firmware version 20080505 and higher versions have the fix. You can download firmware version 20080612 from the HP LaserJet M2727 Firmware Update 20080612 webpage. Click here to go to the HP LaserJet M2727 Firmware Update 20080612 webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3377075&swItem=ma-55531-3&prodNameId=3377076&swEnvOID=228&swLang=8&taskId=135&mode=4&idx=3) . The preceding steps will resolve the issue.
Mar 07, 2011 | HP Office Equipment & Supplies
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again.
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
eliteprintersolutions@gmail.com
Jun 26, 2010 | HP LaserJet M1522n MultiFunction Printer
Reception error need code to get fax out of memory, keep putting in yellow cartridge and says it want yellow
To send or cancel a fax in memory, do the following:
  1. Press Menu/Set, 2, 6.
  2. Using the up/dwn arrows, select the job you wish to either send or cancel
  3. Once your fax appears in the LCD window, Press 1 to cancel the fax or Press BLACK/START to send the fax
Hope this solves your problem. Best of luck!
Greg
Nov 12, 2009 | Brother IntelliFAX 1840C Plain Paper...
Cannot send fax
Jul 01, 2009 | HP Photosmart C7180 All-In-One InkJet...
Sending fax
Try turning off ecm (Error Correction Mode) It appears this may be common on this series. Basically line issues
Feb 15, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
HP LaserJet M1522n MultiFunction Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
