Question about Westinghouse W32701 27 in. LCD HDTV
Westinghouse lcd w32701
The screen is dark. it turns blue for a split second then goes dark. the sound is fine and i can change channels. i called westinghouse and they had no solution. i unplugged and nothing. should i start shopping? westingwouse said it could be a problem with the display panel, whatever that is. HELP!!
  • rxprof Dec 19, 2008
    I have the same thing. It worked yesterday but today, blank screen (blue at very beginning) then nothing. Sound OK. Even DVD player sound present but no picture.
    Any thoughts?
  • rxprof May 11, 2010
    What does "bypass protection circuit, by transferring good signal from working transformer (using 10nF/250V capacitor) to detection circuit at the faulty transformer" mean?
  • 3 Answers
This sounds like bad inverter board.
Every time LCD goes from Standby to ON state - Inverter Board resets it’s self for approx. ~1 sec, during which time you should see blue screen.
Problem is that board detects problem with voltage/current on one of the seven transformers and shuts down automatically...
As to the costs:
- BestBuy repair service approx.. $600.00
- Buy new Inverter Board & repair LCD your self approx. $200.00
- Another option is to repair Inverter Board, but parts are sometimes hard to get...
Now for the DON"T TRY THIS AT HOME or AT YOUR OWN RISK solution:
-The cheapest method is to bypass protection circuit, by transferring good signal from working transformer (using 10nF/250V capacitor) to detection circuit at the faulty transformer.
Then watch movies on your LCD unlit BAD transformer totally BURNS-OUT.
This will be obvious by dark stripe about 1"-2" tall across your display.
Hopefully the only damage will be to the transformer and not CCFL (light behind your LCD), but when you are faced with a choice of using it for a while longer or throwing your LCD to garbage right now... to me this choice was simple.
Good LUCK.
Posted on Jun 03, 2008
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
I got a WESTINGHOUSE that powers on and has a great picture but goes black in about ten minutes still has sound!! i can hit the source button a few times then picture comes back on then same thing all over...
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 13, 2009 | Westinghouse W32701 27 in. LCD HDTV
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Feb 28, 2009 | Westinghouse LTV-30W2 Television
Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Oct 14, 2008 | Westinghouse SK-32H240S Television
Cannot watch channels past 13
Your tuner settings must be set on broadcast instead of cable. Below channel 13, they use the same frequencies so it doesn't matter. Find the tuner settings page in the menus and change the cable/air setting.
Jan 06, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Nov 11, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
No video
Possible bad main board or panel.
May 27, 2007 | Westinghouse W32701 27 in. LCD HDTV
Westinghouse W32701 27 in. LCD HDTV Logo
628 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
