Question about Lanier Office Equipment & Supplies
Lanier Model #7320 Copier SN 826255. Has a wrench
Lanier Model #7320 Copier SN 826255. Has a wrench and won't copy. What is wrong
    President:
  • 1,126 Answers
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Posted on Sep 23, 2009
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
Hi have a lanier copier model 6725. When I make copies it makes the copy and then also prints grey across the entire copy. Looks like it is printing old ghost copies...how can I fix this
Hello!
If you say that you see old ghodt copies the problem is with the Fuser Roller in the Fusing Unit.
If this is right i advise you to call a Tech (if you do not have the skills to change it)
See you!
Sep 02, 2011 | Lanier 1205 Copier
I have a black line on my copies. i have a lanier 7320 copier. Is it my drum?
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Jan 18, 2011 | Lanier 1205 Copier
I have a lanier 7328/7320. It reads side door open on screen. Only the door is closed. Any suggestions
How are you? This is a problem with front door switch.
Remedy
  • Place the machine on a level table and make sure all the four stands are landing freely on this table.
  • Check that the front door notch that closes the door switch is not broken and if it is replace that particular door or modify the notch.
  • Make sure the upper half of copier is well locked with the lower bottom part.
If all the above is correct, and still reads open, replace the door switch.
Good luck.
Nov 15, 2010 | Lanier Office Equipment & Supplies
Lanier 7320 error message c-41 can someone tell me whats wrong
I believe c-41 is a fuser problem. A trained copier tech may be required to troubleshoot.
Mar 19, 2009 | Lanier 1205 Copier
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Jun 09, 2008 | Office Equipment & Supplies
Misfeed on lanier 7320
Sounds like a dirty sensor or a small piece of paper stuck. Check the feeder, left side, underneath. There should be a switch actuator
in the paper path that is visible. Also, on the right side, check all of the openings for anything stuck. If you have no luck, get some canned air and blow out everything. If its still jammed, it can be easily unplugged in the back of the machine, and the machine section will still operate.
Apr 23, 2008 | Lanier 1205 Copier
Printer problem
You need service on your copier. It might just need a cleaning, or possibly a part. If they are random spots on your copies, then there is a good chance the cleaning unit seal needs to be replaced.
Jan 24, 2008 | Office Equipment & Supplies
Lanier Copier User Manual
Go on line to Lanier.com, chose manuals. Then put your model in and that you want the users manual and down load it. Most of these kind of manuals are free to copy.
Oct 13, 2007 | Office Equipment & Supplies
199 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
