Question about Texas Instruments TI-89 Calculator
How do i set my ti 89 titanium to factory settigngs
How do i set my ti 89 titanium to factory settings. so it was like i just got it out of the package.
  • 496 Answers
Ti-89 titanium diagnostics
There is no DiagnosticsOn command in the TI 89 Titanium. The command exists on the TI83/84PLUS where it displays the r and r^2 coefficients. On the TI89 , the correlation coefficient and the determination coefficient (r, r^2) are displayed by default among the statistics if THE REGRESSION MODEL includes them. If they are not defined by the regression model they will not be displayed. In short, you do not have to turn diagnostics ON.
Apr 17, 2012 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
My TI-89 Titanium won't graph sin, cos, or tan?
Set your calculator to RAD mode and then graphing functions.
See example for y=sin x
Nov 10, 2010 | Texas Instruments TI-89 Calculator
How do you program the ti 89 titanium to do fractions
Press MODE F2 then scroll down to Exact/Approx, press right-arrow, and select either AUTO or EXACT. Press ENTER twice to save the settings.
Sep 02, 2010 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Sep 22, 2009 | Texas Instruments TI-89 Calculator
Ti 89 Titanium
The only option or keys that will work is the ENTER key and the arrow keys. Try to get your arrow key to work by arrowing down and hit enter hopefully change you to something different.
Next, if at all possible can you hit the MODE key or get into the mode. If you get into the MODE select F3 and then arrow down twice or all the way to the bottom and at APPS Desktop select 1:OFF and then hit the ENTER key. Next, What I really think you need to do is reinstall the Ti 89 OS software. To do so you would need to connect to your computer or another Ti 89 Titanium to your Ti 89 Titanium. If you have Ti connect computer software (from the Ti site) connected to your Ti 89 Titanium it might help you more in troubleshooting any further problems too. You might be able to delete corrupt files that would free your calculator up and start running better.
Sep 03, 2008 | Texas Instruments TI-89 Calculator
Ti-89 titanium
the comma is close to the "(" and ")" simbols
Sep 01, 2008 | Texas Instruments TI-89 Calculator
Dec to hex conversion
Not sure if TI-89 mode keys are the same, but here's the solution for that calculator:
1. Hit the mode key
2. Hit F3 to get tot Exact/Approx (might be different for 89T).
3. Set it to Exact.
4. Take a look at T-89 manual pages 327, 328, 329.
Nice of TI to NOT include that in the manual, huh?
Dec 13, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
522 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
