Question about GE Refrigerators
We have a refig.. with top freezer. Freezer works fine, refrig. is not working, motor still runs when turned up. About 8 years old. What could be wrong?
  • 98 Answers
Make sure the fan in the freezer is running. if it is . More than likely the vent has ice in it. take the bottom out of the freezer and you can get to it. throw the ice and then check the drain. is right behind the vent.
Posted on Sep 24, 2009
We have a Whirlpool with the freezer on top. The freezer is around 5 degrees, but the refrig. won't go below 47 even at the coldest setting. We vacuumed all of the vents and tubes in the lower front
The fan in the freezer may have stopped working. Or it could be the defrost drain tube is stopped up. Remove the rear plate in the freezer to expose the fan motor. With the rear cover off You can see if the freezer box has frozen over the drain. If so unplug refrigerator use a hair dryer to melt the ice. Keep heating the drain area until water runs down through the drain. Fan motors are available by model number on line or at local appliance stores.
Dec 30, 2013 | Whirlpool Refrigerators
Freezer work but refig isn't is there something that regulate the cold air from freezer to refig beside the one in the refrig becuase it't working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | Maytag Refrigerators
Fan seems to be working, but feezer and refrig. not as cold as should be, ice cubes not freezing over night. fan motor was replaced about a year ago. refrig. is about 8 years old
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 26, 2010 | GE GTS22KBP Top Freezer Refrigerator
Freezer works fine, but cooler is not cold. How can I fix it myself? Is it worth it to repair it or get new one? It is 8 years old.
Have you tried cleaning the coils? I also lost cooling on the refrig side and it was fixed by a thorough cleaning of the the whole (in my case) underside of the unit. Your coil may be along the back. That was 8 months ago and it has been fine since. Depending on what needs replacing, it is probably not worth fixing unless you have a super top of the line model.
May 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Have kenmore refig model 59671103101 refrig temperature to low. light work, fans run freezer works good. Cleaned vents & coils ?
if the freezer is fine, check for air flow to fridge. if you get none, see if there is any frost on the back wall of the freezer. if there is some frost, the coils are iced up and need thawing. if there is no frost, there may be an obstruction in the vent. also may be thermostat in fridge- it opens and closes the vent from the freezer.
Nov 13, 2009 | Kenmore Refrigerators
GE GSS25LGM freezer not working. It's about 8
it seems like the thermostat on the freezer side is not function right but does the motor of the freezer run or not if not check thermostat
May 16, 2009 | GE GSS25LGM Side by Side Refrigerator
My refige is warm and my freezer is frosty
lg american fridge freezer my fridge is working ok but my freezer isnt can u help please ty
Dec 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
