Question about RTO PasLode 900420 Impulse Framing Nailer
Paslode gas nailer trim gun
If gun is inverted/upside down will not compress wire on head to allow firing, almost like theres a pendulum inside not allowing the retraction of the firing compression wire on tip of gun. confused
  • David Ford
    David Ford May 11, 2010
    So am I, are you saying the gun won't fire upside down? But will fire normally the other way? Please let me know and I will try and help
  • 55 Answers
There is no pendulum inside these guns it should work no matter what angle or upside down you are shooting it. If it is not retracting the piston trying cleaning the area and then lubricating really well that should do it if not repost and tell what that does.
Hope it helps you
Posted on Dec 01, 2009
My paslode im350 will only fire at 90 degrees and not in any other positions has any one got any ideas what the problem is?
You or who ever worked on your tool last didn't replace the lock out spring. I see this all the time. Its a little spring that holds the lock out down so the safety can engage. I bet when u try to fire the gun upside down the safety doesn't go all the way back.
Sep 13, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
heatman101
Oct 24, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I have a paslode gas framing gun when i want to nail something it makes all the sound but does not fire gas cell is good battery is good
heatman101
Sep 14, 2010 | Porter Cable FR350A Factory Reconditioned...
Paslode framer when you depress trigger there no resistance and it does not fire
Paslode framer has a lever inside of trigger that may be bent or missing. Easy to check. Remove air line and nails. Remove trigger by pulling pin. Check under trigger for missing parts. Test gun by connecting to air and place nose of gun against wood or hard rubber and then depress firing pin. If gun fires then problem is with lever under trigger or safety mechanism which is in two parts. Check safety for bent or broken piece, usually upper part will be missing lip that actually pushes on the lever. If however gun does not fire when firing pin is depressed, time for replacing orings in gun. Parts are available at www.toolpartsdirect.com . Good luck with your repair and post again if you have other questions.
Jun 30, 2010 | NRS Paslode 501000 Powermaster Plus...
My finish nail guns, 16 ga won't fire.
There is a little plastic piece inside above the trigger...usually this breaks. It touches a microswitch when the cylinder is closed all the way, allowing the nail to fire.
Oct 04, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Shoot no shoot
make sure that the filter in the back is clean you can pop the back cover off and clean it with water if it is dirty then the excess co2 gas that the gun gives off will not be able to excape the chamber and sensors inside the gun will not let if fire. This should work for you
Sep 01, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode fires just as you realease the gun from the surface
sounds like the trigger m8 the only way to cure it is to replace the molded circuit assembly 900475. but try cleaning the trigger switch and make sure the spring is seated properly. hope this helps m8
john
Jun 09, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Firing pin not retracting far enough to allow nails forward
Yes,this is a common "mis fire" by Pasilode. I own the 16p Framer and the Angle nailer and I never get it from the Framer but I do get it seldom from Trim Gun,nothing you can do ,its just a misfire.
Please rate jj505
Mar 20, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
RTO PasLode 900420 Impulse Framing Nailer  Logo
288 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
