Question about Jane Powertwin Azulon Stroller
My rain cover is torn i need a new one how much do you charge?
  • 419 Answers
If you contact www.johnstonprams.co.uk you will be able to purchase a replacement.
I hope this helps.
Posted on Sep 23, 2009
1170XL Plus Pride wheel chair problems, VSI shows full charge, and gets hot after a few hours
Medicare should be able to help you locate a service center. The controller has some electronics that may have been damaged by the rain. It needs to be tested for sure.
Jul 29, 2014 | Pride Health & Beauty
Tip
A New Hot tub cover will lower your Hot Tub Costs
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
  1. The hot tub cover weighs over 100 pounds.
  2. You need more then one person to remove the hot tub cover.
  3. The hot tub cover is ripped and torn past repair.
  4. Faded cracked and just aesthetically ugly.
  5. The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
on Sep 05, 2015 | Home
My 2006 H3 has water leaking into drivers side floor
While H3 is parked on driveway, driver floor mat is removed, and steering turned all the way right to expose splash area, pressure hose the front left steering splash area behind left tire while another person feels with their hands to determine where water is entering. If the leak is beneath, it would only enter when you go through flooded area. When it rains, the water constantly splashes behind the tires, which is an area source for water to enter the driver area while the vehicle is in motion during rain condition. If you live in snow area, they use salt to keep roads clear of snow. Salty water is highly corrosive to exposed steel. In the summer or fall season before snow begins, you steam jet pressure clean the underside, then inspect for any area where undercoating had come off. Take primer spray paint and cover these exposed areas with at least 3 coats of primer paint, or rubber sealant spray.
Nov 29, 2013 | Hummer Cars & Trucks
Water leaking into driver side front and rear floor
had this problem and the answer was the liner inside the door was loose or torn allowing rain to get through to the outside. dealer fixed it and no problem last eight years
Oct 25, 2011 | 2001 Pontiac Bonneville
Trunk is leaking water after a rain.
Open the trunk, and look at the seal. Is it torn ripped, or flat in areas? Also is there old leaves or trash built up around the seal? You can get a new seal from the dealership, and is easy to replace. It just pushed into place. Just make sure the seam( or ends) are in the center at the bottom of the trunk. Being rubber, they do wear out.
Dec 29, 2010 | 1994 Buick Park Avenue
I accidentaly torn the waveguard cover for my new oster microwave. Its torn about half way across but still can remain in place. Is it safe to use the microwave?
The waveguide cover will need to be replaced.
It provides critical protection for the magnetron.
You can contact Oster at the number in your owner's manual to see where you can order a new one.
If for some reason you do not have your manual, try 1-866-866-6283.
Jan 31, 2010 | Westpoint TV-201 Microwave Oven
I was cheated. . . need advice
You didn't buy this from a dealer did you? Try (repairpal.com) for estimate for repairs that zero's in on your area rates via postal code for closer estimate. You just enter info on vehicle & pick repair to be done.
Mar 27, 2009 | 1992 Honda Accord
Rain cover for Baby Jogger II Twinner 20 Alloy
Since the stroller is discontinued you may consider going to a boat cover shop and having a rain cover made. They will put in the window and everything in whatever color you choose.
Feb 12, 2009 | Baby Jogger 2 Stroller
Battery in my 2006 Audi A4 2.0T Quattro is exposed to rain.....
I checked prices at a large parts store chain, and they had 3 battery choices for your car, 2 were $150, and a 3rd was $90. Was the $150 u mentioned for installation only? I'm wondering what they charged for the battery? I' m not familiar w/ the location of the battery in your car (some GM models are located under the rear seat!). Any rain entering the engine compartment (there shouldn't be much due to gaskets/weather stripping around the hood), would not harm the battery. Actually, heat is an enemy of the battery, and it's plenty hot under the hood, so in theory, any rain that did enter and contact the battery would be good, as it would have a cooling affect. Eliminating the cover may have been done as a way to dissipate heat. Let me know where the battery is located, as it may be someplace unique, but if it's under hood like most cars, rain is not an issue. I do want to know what the total cost of the battery was, and if I understand correctly that $150 was for installation, not the cost of the battery.
Dec 15, 2008 | 2006 Audi A4
Jane Powertwin Azulon Stroller Logo
57 people viewed this question
Top Jane Baby Gear Experts
D. E. Hev
NOEL
NOEL
john h
Are you a Jane Baby Gear Expert? Answer questions, earn points and help others
