Question about Dell (6F858) Cooling Fan
How do you remove a TA450DC fan from a dell computer?
    Scholar:
  • 161 Answers
Its the clips on the side of it. you need to push one down while lifting another. pain in the ***.
They fixed this problem later lol.
Posted on Apr 06, 2010
2 Suggested Answers
  • 59 Answers
SOURCE: Dell E521 computer, AMD Athlon? 64 X2 Dual-Core 3800+
If you go to Yahoo and search in shopping you can find the exact same one in there and just decide on which price you want to pay. Here is what I searched and found.
http://shopping.yahoo.com/search;_ylc=X3oDMTEwNTByOW5sBF9TAzI3MTYxNDkEc2VjA2ZwLXRhYgRzbGsDc3Bpcml0?p=Nidec+TA450DC&fr=fptb-msgr&toggle=1&cop=mss&ei=UTF-8
Posted on Feb 28, 2009
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
REAR FAN FAILURE DELL OPTIPLEX 755
This is the rear fan
Replacing a Hard Drive Fan
  1. Follow the procedures in Before You Begin.
  2. Remove the computer cover (see Removing the Computer Cover).
  3. Remove the hard drive (see Removing a Hard Drive).
  4. Turn the hard drive upside down, so that the hard drive fan is visible in the bottom of the drive bracket.
  5. To remove the hard drive fan:
    1. Lift the release tab on the back panel of the fan.
    1. Rotate the fan in the opposite direction from that indicated by the arrow on the back panel of the fan.
    2. Lift to remove the fan and its back panel from the hard drive bracket.
klamma16.jpgReplacing a Hard Drive Fan
  1. Follow the instructions in Before You Begin.
  2. Remove the hard drive (see Hard Drive).
  3. Remove the hard drive fan:
    1. Remove the screw that secures the fan release tab to the hard drive bracket.
    1. Press down on the fan release tab, and then slide the fan towards the front of the computer so that its side tabs are free of the corresponding slots in the hard drive bracket.
    2. Lift to remove the fan from the hard drive bracket.
    3. Unplug the fan.
May 30, 2011 | Dell Optiplex 755 Ultra Small Form Factor...
1) How to you open the cpu case to get to the fan, etc. 2) My fan has started making noises......can it be cleaned - or is it likely to need replacement?
Things You'll Need:
  • phillips Screwdriver
  1. Shut down your Dell desktop computer.
  2. Remove all of the power and peripheral cables from your computer. There should be no cables connected to your computer when you attempt to remove the cover and open the case.
  3. Watch for the green "Power" indicator light to dim. This light is on the back of the case near where the power cable plugs in. Your computer will hold onto an excess amount of energy for a few seconds after it is unplugged. You don't want to open your Dell computer case while this light is still lit.
  4. Use a screwdriver to remove the screws holding the side of your Dell desktop computer's case. Set the screws aside.
  5. Use your hands to pull up on the side of the case, separating it from the base of the computer. This will allow you to access the inside of your Dell desktop computer.
Jan 23, 2011 | Dell Dimension 2400 PC Desktop
I have dell dektop pc optiplex 755 but if i turn it on the fornt shows amber and no display as well. kinldy help cos am confused
remove the cover of the computer remove the memory from the slot and wipe *** clean with a dry cloth insert them back into the slot andrestart your computer if not weorking remove the cpu fan and the prcessor from the socket replace the processor in the socket wipe clean the processor and the cpu fan paste a thin layer of heatsink solvent and replace the cpu fan to processes and fix it tightly and restart the computer
Nov 29, 2010 | Dell Optiplex 755 Desktop Desktop Computer...
My DELL Dimension 5150 fan is making a great noise, how can I fix it?
Turn the computer off.
Disconnect the AC power.
Remove the side-panel.
Buy a can of compressed-air, and give your computer a "blow-job" to remove dust from "everywhere", including the fan(s).
If you still get noise, then it's time to replace the fan.
Take the computer to any computer-store, so that they can sell you a new fan that matches the current fan.
May 07, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I need to remove the fan. I know how to open the case, however I just can't seem to gain access from the metal cover even with all the screw removed.
All WHAT screws removed? You pull back on the Release Lever, then lift the side panel off!
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/cvrop.htm#wp1052950
This is in reference to a Dell Dimension C521 Desktop PC, correct?
Here.
This is the Service Manual for the Dell Dimension C512 Desktop PC,
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/index.htm
Go down to the heading - Removing and Installing Parts, and left-click on it.
Now click on the heading - Fan Assembly
Anything else I can help you with on this computer?
Jan 21, 2010 | Dell Dimension C521 PC Desktop
Dell D800 laptop cooling fan issue
If you want to know all the details of your hardware software ect...
I would recommend downloading SIW http://www.gtopala.com/
If the computer does boot up I would simply suggest buying a replacement fan they generally only cost about $10-15 and take only a minute or two to replace
Here is a link to Dell's part ordering page just select your machine type, if its custom made, you can remove the fan and find the part # on it and search Dell's site by the part # http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&s=dhs
If you need further assistance feel free to leave a comment
Nov 21, 2009 | Dell (6F858) Cooling Fan
Feb 28, 2009 | Dell (6F858) Cooling Fan
Noisy fan
We have a Dell Dimension 4700C too. We had it on a 3-year warranty and the only problem with it was that from that to time it would become abnormally noisy, too noisy in fact. Dell sent a repair guy twice, and they changed the heatsink/fan assembly unit both times, and the third time we did it ourselves (it's not that hard to do), but here's the thing, we noticed how DUSTY it was when it came out, we wondered how it even worked with all that dust. So, now our warranty has expired, and guess what, the computer started making that terrible racket again, so this time, we opened it, armed with the vacuum cleaner and a can of compressed air, gave the whole inside of the computer a good once over, removed the heatsink/fan assembly and cleaned it thorougly (you can't do this unless it is out), and it worked like a charm, can't even tell the computer is running. Hope this helps.
Nov 09, 2007 | Dell Mini Fan. Dimension (W x H x D) in....
Dell (6F858) Cooling Fan Logo
152 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
