Question about Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher
Rinse and dry
Dishes come out with a feeling of grit remaining on dish. Soaking in hot soapy water will remove it
  • 14 Answers
You probably don't have enough pressure from the pump. That's most likely caused by a clogged filter. So start by checking the filters- the easy one to get to is located behind the chopper in the base of the dishwasher. Grab the whiteish tube going from the bottom of the dishwasher towards the back of the dishwasher and get it to spin about 1/8th turn clockwise and then pull up. If that part works out for you, you'll see four torx screws. Don't loose any of these, they cost $6 each. Take out all four and pull the round white thing up and set it aside. You'll see gray plastic now. Towards the front, down inside, you'll find two more torx screws that are smaller than the first four. Take those out and get the two gray pieces they hold down out of your way. The flat one will come out easily, the other one will take some persistence. Once you get that out, you can see the smaller filter behind the chopper. It sits inside a thin groove, pay attention to this groove, as you'll want to put it back in the wrong place if you don't look it over before you take it out. Remove the filter and chopper assembly and clean it off if it's a mess. Then put the thing back together the same way you took it apart.
If this fixes your dishwasher, then you know pressure was your problem. If the problem reappears and you follow these steps again only to find the filter full of food again, then your chopper isn't chopping anymore. This is probably because the end of your impeller is broken off and isn't engaging the chopper anymore. If that's the case, replace the impeller (about $20 new).
To replace the impeller:
SHUT OFF THE ELECTRICITY to the dishwasher and unhook the wires in the electrical connection box. Notice that (hopefully) the white wire connects to a white wire and the black wire connects to the black wire and the green or bare wire wraps around a screw. You'll need to reconnect this back properly when you're finished with everything else.
Disconnect the drain line, either at your garbage disposal or at the dishwasher if you can get to that connection. Watch out for water, it'll go everywhere when you pull this loose.
Turn off the source of water, if you don't have a valve under your sink for this (you'll wish you did) then you'll need to shut off the water to your house. Disconnect the water supply line from the dishwasher, this connection is underneath the dishwasher opposite the electrical connection box.
Pull the dishwasher out and flip it over 45 or 90 degrees, your choice.
Unscrew the capacitor from the motor assembly (it's the round looking thing with two wires mounted to the motor), but leave the wires connected to it. Put the nut back on the bolt so you don't loose it. This makes getting the thing out easier.
Find the drain pump, it has a plastic tube connected to it. There is one torx screw holding that in. Take the screw off, pull the tube and the white thing with wires out, leave its wires attached. Your model may not have wires here.
Pull the wire connector off the motor. Remember where it went. Pull the two wires off the thermistor, they should be Yellow (with a black stripe) and white. Make a note that these two wires go on the thermistor so you get them back in the right place. Pull the Blue and gray wires off the drain pump. Make a note that these go on the drain pump so you get them back in the right place.
Next, there are three tabs that you need to find and pull out. They are little L-shaped wedges that hold the round gray assembly to the dishwasher. They are located about 1/3rd of the way around the circle, so once you find one, the other two are pretty easy to locate. Do not loose these parts.
Once you get those pulled out, the entire gray assembly can come out.
Look behind the motor for a bolt. Get your socket set out and find a 3/8ths socket. Put that on an extension, and the extension on your ratchet. Slide the socket between the white plastic protector and the grey plastic (it's a tight fit) and take out the bolt. Do not loose the bolt. Leave it in the plastic so you'll remember to put the plastic back. Grab the motor and turn it about 1/8 to 1/4 turn (it will only turn one direction) and then pull it out of its housing.
From here you can access the second filter, the one that isn't so easy to get to. It's probably fine. And now you can see the impeller, it's white and black and attached to the end of the motor shaft.
To remove the impeller, stick a screwdriver into the back of the motor, being careful not to damage the windings. Hold the screwdriver with one hand, grab the impeller with the other hand and unscrew it from the motor shaft.
Install new impeller on the end of the motor shaft, make sure it's tight.
Reverse instructions to put it all back together. Make sure you get the thermistor and drain pump wires connected correctly. White/Yellow to thermistor (little round dodad) and blue/gray to the pump (big thing on the gray part that drains water from the tub.)
Don't forget to re-attach the drain and supply lines, turn on water and check for leaks. Fix leaks. You may need Teflon tape, depending on the type of supply connection you had to undo. If you use plex tubing and connectors, you don't need Teflon.
Do NOT turn back on the electricity until the dishwasher is completely wired back up, closed, secure, and don't forget the ground (bare or green) wire around that screw.
I'm not responsible if you follow these instructions and end up shocking or killing yourself or your dishwasher. This is what worked for me.
Posted on Dec 29, 2007
My indesit dishwasher is not drying when the cycle is finish
Possibly the drying /heater element is faulty. Check the machine isn't on a non drying cycle. Some machines will do the last rinse in hot water but leave the dishes to drip dry in the hot humid air after the rinse. If the dishes or water isn't hot during a rinse , I would say its the element.
Mar 21, 2017 | Indesit Dishwashers
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
What causes grit to dry onto dishes after dishwasher has finished?
Check water hose leading to the dishwasher for deterioration..
May 11, 2014 | LG LDF6920ST Stainless Steel 24 in....
Leaving grit on dishes that are mainly on top row
The upper spray arm is powered by water from a tube that runs up the back of your machine on the inside. If the connection is not aligned, then the water can't get to the spray arm. My children use to knock mine out of kilter when they loaded the lower section. It's easy to see if the supports are not attached to the upper rack and a simple snap will get them back in place.
You may have clogged jets in the upper spray arm.It will need to be removed so that you can soak it in hot soapy water and then flush it with hot water. You may also need to take a toothpick or tweezer to remove any debris that clogs the jets.
Finally, check the bottom of your door on the inside of the dishwasher. It's amazing the "gunk" that can collect there. This gunk can be redistributed to your dishes. I put some soapy water in a cup and use an old toothbrush to clean this area. Then I rinse twice with hot water. Finally run the dishwasher with 1/2 cup of white vinegar while empty.
This should take care of your gritty dishes. I hope so. If it does, please come back to Fixya and rate my advice!
Jul 21, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
My diswasher won't dry my dishes. It leaves them
if no rinse agent is present it doesnt matter how hot the water gets they will still not dry check unit make sure it is full. rinse agent is only to aid the drying process the machine will wash happily without it but not dry.
Feb 15, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher rinse water is soapy
if you noticed the white film after they were dry it's your water if not reduce the amount of detergent i prefer the powder mysef
Feb 20, 2009 | KitchenAid Dishwashers
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Dihes not clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
HElp Dishes not coming clean
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Whirlpool GU1100XTLB / GU1100XTLQ / GU1100XTLT Built-in Dishwasher Logo
133 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
