Question about Baby Gear
Dont know how to use seat with car seatbelt - Baby Gear
  • Kristy Mahar May 11, 2010
    needto know what type of seat and what type of seat belt
  • 14 Answers
It's impossible to tell without more information. There are usually pictures and instructions on the sides of the seat. I believe that your nearest fire station will help you, and that is probably the safest route to take. Good luck to you.
Posted on Oct 11, 2009
Disable seat belt warning
use a seatbelt male connector off a wrecked car is the easiest way but dont know why you would want to disable the seat belt light as it is a safety warning device
Jul 22, 2014 | Mitsubishi Mirage Cars & Trucks
Middle back seat: seat belt is locked up & will not release!!!
DO NOT CUT YOUR SEATBELT!!! Simply unbolt the seat from the body, unbolt the seatbelt from the body under the seat, tilt the seat forward, pull the seatbelt and part that attaches to the body between the seat cushion and backrest and release the tension. Not the easiest fix, but it only takes 30 minutes to do, and will save you a LOT of money. If you cut that seatbelt, you will be buying a new rear seat.
Apr 08, 2013 | 2009 Pontiac Torrent
Seat belt light flashes after seat belt is on
The new 2013 Bentley Mulsanne Mulliner has the same thing.I know on the Bat Mobile it means the ejector seat is not fully charged.
The only generic answer I can conclude with information you provide is ;
1) The passenger seat of a newer general motors car
2) The seatbelt light does not light up when the seat is not occupied
3) The passenger side Airbag (SRS) has been turned OFF
4) While occupied , the seatbelt light on the insrument cluster lights steady
5) when the seatbelt is active (buckled with a passenger) the light flashes.
6) anybody?
Mar 31, 2013 | Cars & Trucks
Seatbelt chime
There is a switch in the buckle that senses when it is fastened. This might be stuck or the sensor that tells if the seat is occupied is bad.
Aug 13, 2012 | 2009 Nissan Murano
Is there a passcode or sequence to disable the
As far as I know that seat belt warning chime and light is there for your safety and protection, it should not be bypassed in any way.
There is no by pass seqwuence or code to eliminate this safety device.
Buckle up, its the law.
May 09, 2010 | 2002 Ford Mustang
My back seat middle seatbelt is locked and the seat is folded down. how do i unlock the seatbelt to raise the seat back upright
That just happened to our 05 equinox. We have car seats so one of the seats was reclined just a bit. This will cause the seatbelt to lock. We took out the car seat, folded down the other seat and folded it back. It cause the locked seat to release and unfold.
May 05, 2010 | 2005 Chevrolet Equinox
How do you fix a stuck seatbelt in front seat passenger side? The seatbelt has retracted but will not release outwards to enable its use. We have pulled off interior cover of the seatbelt to get access to...
this is a simple repair many dont know. remove or pull off plastic pillar post cover, seatbelt probably twisted inside. twist it back around so it runs flat and lube slightly with a light lube spray on metal gearing. i had the same problem w mine pk
Jan 16, 2010 | 1998 Ford Taurus
Seat belts
MAKE A CUT WHERE THE SEATBELTS MEET,PUT THE SEATBELTS THRU, THEN COVER THE SEATS ,AND THE SEATBELTS SHOULD BE FINE
Oct 28, 2009 | Cars & Trucks
I replaced the headline recently and lost the parts to attach the rear seatbelts back up, what do I use?
The bolts at the end of the seat belts should be screwed into the mounting holes in the floor, which I believe are threaded at the ends, so u shouldn't need anything at the end of the bolt. Let me know if this is not correct.
Nov 02, 2008 | 1993 Jeep Grand Cherokee
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
