Question about Wahl 79110 Hair Trimmer
The power cuts off when the cord is in a certain position. The problem would appear to be near the base where the ac conects to the clipper. Is this something I can fix myself?
    Sniper:
  • 61 Answers
You can take the lid off the clipper (make sure it is not plugged in) and check that the power cord terminals did not come loose. However if that is not the problem, you probably have a bad cord that needs to be replaced. If you return it to Wahl factory in Sterling, IL, 2900 N. Locust St., they will probably replace it for free.
Posted on Sep 27, 2009
Babyliss pro needs a new cord
un screw it, then take from the base cut where broken and afix the points to there positive and vegative,then seal the whole device together......happy days
Sep 10, 2016 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
How do i fix the power cord on a wahl switchblade clipper
depends on where the cord is broken. find the spot thats come apart and cut it out, resplice the cord and your good to go. of course your warranty will be no good, but how often do they replace things that way any way. even if they do you have to wait weeks for the replacement.
Feb 04, 2014 | Wahl Switchblade Professional...
Conair hair clippers repair
It could be the switch is shorting out or the cord is. If it doesn't cut off when you move the cord it is prob the switch.
Apr 22, 2013 | Health & Beauty
Power comes and goes
Hi I know its a late reply but this sounds just like a power cord problem you can buy a new mains lead for the clipper from UK based company Anglia Clipper Services
Apr 20, 2013 | Andis AGC2 Hair Trimmer
Power jack is broke. want to connect to battery pins off motherboard. need pin assignments. i found them for the power jack but cant find for battery connection.
it is nearly just as easy to cut the conection of the power cord and weld it strait to the board where the conection was, or use a volt meter and trace the conections back to some where more stable, conecting strait to battery will or might do damage and the laptop will think it is always running of the battery. and or also could over charge the battery because you are bypassing the switch that stops it. hope this helps a bit.
Dec 02, 2009 | Dell Inspiron 6000 Notebook
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
The clipper suddenly cut off how do i get power to the andis or do i needa new set. This set is only a year old. does anyone know where i can get instructions.
Chances are that the problem wasn't the clippers at all. Since they were on initially, maybe you tripped a circuit in the breaker box? If that wasn't it, you may have damaged your cord. I see a lot of people pulling by the cord to unplug...BAD decision. Check for frays near the end that houses the prongs, and if not there, open them up and check from in between where the hanging loop is up to near where it connects to the motor. I still have every set of andis trimmers and clippers I have ever owned.
If your afraid to open them up, go to andis.com, then click your country, then hover over professional and scroll down to trimmers. Select the outliner II, and when the next window opens, at the bottom there is a specs link. Click that and you should find a diagram of what your looking for when you open up the housing.
Oct 12, 2009 | Andis T-Outliner Hair Trimmer
Power cord is loose, power cuts off
If its the Auto wind cord then fault could bre internal contacts, not easy to get into suggest best to go to service centre.....
Oct 10, 2009 | Miele s558 Silver Moon Vacuum
It keeps geting hot every time i cut my hair
you should put clipper oil where the blade contacts it's base (near the middle of the base) and spray kool lube or a similar product on the cutting edge.
Aug 08, 2009 | Andis T-Outliner Hair Trimmer
It won't charge
i had the same problem and noone was able to help me "shame"
so what i did is.. open the base "where you place the machine for cordless charging" then get the adapter at the end of the cord there is the connecting part "input" the one u stick it in the machine's *** for corduse cut that part "input" from the adapter and you connect it str8 to the base "inside" and i promise it will work.
mine working now cord/cordless
PS: to keep using it cord buy another adapter and cut and connect and keep yours for cord use!
hope i'm more useful then the people runing this show.
Oct 16, 2007 | Vidal Sassoon VSCL870 Hair Trimmer
Wahl 79110 Hair Trimmer Logo
133 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
