Question about HP LaserJet 2840 All-In-One Printer
Help with error code 50.2 fuser. Tried to reset printer as instructed, but problem persists.
Replace drum errore
Posted on Oct 04, 2009
  • 99 Answers
YOU HAVE NO CHOICE BUT TO REPLACE THE FUSER ASSY.
YOU CAN ORDER IT AND INSTALL IT YOURSELF ITS PRETTY EASY.
SORRY....
Posted on Sep 24, 2009
    Problem Solver:
  • 10 Answers
Sir,
If you experience a "50.2" fuser error while using a LaserJet 4000, 4050, or 4100 fuser, you should check to see if two tabs on the fuser have come loose
Turn your printer off and remove your fuser. Flip it to the gear side (the left side) and press inwards on the fuser tab to make sure it is fully clicked in place
Posted on Sep 23, 2009
How to reset error E000-000 for Canon ir2202
To help you understand and troubleshoot the error E000-000 for Canon ir2202 printer, please follow step-by-step instructions given below:
This error occurs due to high temperature readings on the printer. Occasionally, the fuser will run too hot. First thing is to perform factory reset on your canon printer but if it still show error code E000-000 again, then try to reset it in Service Mode. To do these, follow the steps below:
- Press ADDITIONAL FUNCTIONS, #
- Go to #7 Printer and Press OK.
- Go to #4 Printer Reset and Press OK.
- Yes = ( * )
- Power cycle unit.
Now check it the error is resolved. If issue persists, please try definitive reset. To do these, follow the steps below:
- Press Additional Functions key.
- Press #
- Press > to #7 Printer Function.
- Press Set.
- Press > to #4 Printer Reset.
- Press Set.
- Press <
Now restart the printer and check if it resolves the error. If issue persists, it is recommended to contact Cannon Support Center from the link given below:
https://www.usa.canon.com/internet/portal/us/home/contactus
GuruAid.com
Jun 14, 2016 | Canon Office Equipment & Supplies
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
When I turn the Printer on, it will initialize and then display an error message "50.7 fuser error" and will not get to 'ready mode' for printing
1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board. http://printertechs.com/tech/error-codes/error-codes-50-59.php
Fuser Ref: http://computer.howstuffworks.com/laser-printer3.htm
May 05, 2011 | Computers & Internet
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
HP LaserJet 4MV '50 service' on an HP LaserJet 4MV printer Can it be cleared without resorting to repairs or replacement parts?
You could remove the fuser, turn the machine off, and wait an hour. It may reset the error. However, if the error still persists, it will be a parts replacement of the fuser, low voltage power supply, or the DC controller. 90% it is the fuser. Good luck.
Apr 21, 2010 | HP Office Equipment & Supplies
Laserjet4 50 intervenire
X FUSER ERROR A fuser error has occurred. 1. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Apr 07, 2010 | HP LaserJet 4 plus Printer
I GET ERROR CODE 010-349 WHEN TURN PRINTER ON
Hi!
The error issue your printer is facing means "Fuser STS Front Disconnection fail"
First try to reset the printer by powering off and then on. If the problem still persists then you need to detect fuser or fuser assembly which is required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 25, 2009 | OKI B6300 Laser Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
Mar 23, 2009 | HP Color LaserJet 3500 Printer
Cannot reset code 50 for service
50 error is the fusing assm. You need to replace the fuser then the error will go away.
hope this helps.
Mar 23, 2009 | HP LaserJet 4 plus Printer
HP LaserJet 2840 All-In-One Printer Logo
517 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
