Question about HP Office Equipment & Supplies
WILL INITIALIZE DESIGNJET Z6100\r\nPOWER LIGHT
WILL NOT INITIALIZE HP DESIGNJET Z6100 POWER LIGHT BLINKS GREEN, BACK LIGHT ON CONTROL PANEL COMES ON, NO TEXT. THEN POWERS OFF.
P/S LIGHT COMES ON BLUE. PRINT MECH BOARD 24V LIGHT OFF, VPOWER2 LIGHT OFF.
WILL NOT RUN ANY DIAGNOSE.
HAVE REPLACED THE POWER SUPPLY SAME PROBLEM.
  • 400 Answers
HP only mention error messages :
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3338748&prodTypeId=18972&supportTaskId=22993
you don't even get that far ,are you able to remove the cartridges?
Seems to be a curcuit board problem
Posted on Sep 23, 2009
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
HP DesignJet Z6100 Error 43:10
Hello. The error message indicates a vacuum fan failure. The problem can be solved by replacing the Vacuum Fan Assembly.
Q6651 60286 HP Designjet Z6100 Vacuum Fan Assembly
The service manual with instructions can be downloaded from: http://www.lpscomputer.com/collections/designjet-z6100-parts
Jul 22, 2014 | HP Designjet Z6100 InkJet Printer
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
I have a hp z6100 and it keeps saying load roller
Do you mean load up Take up Reel, in which case the Take up reel option can be switched off in the paper menu accessible from the front panel on the Z6100.
Feb 22, 2013 | HP Designjet Z6100 InkJet Printer
Hp z6100 plotter error code 46:03
System Error:
46:03
Problem Description:
Primer servo shutdown.
Corrective Action:
Try the following:
1. Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2. Replace the Primer Assembly .
3. Replace the PrintMech PCA .
4. Replace the Interconnect PCA .
Feb 06, 2013 | HP Designjet Z6100 InkJet Printer
Hp designjet z6100 error code 21 : 13
Service Station error. Switch the power OFF from the back of the Printer and disconnect the power cord. Check the Primer Tubes. Reconnect the power cord and power On the Printer. Make sure that the Service Station path is clear. Remove any visible obstacles (e.g. screws, plastic parts, etc...) restricting the movement of the Service Station. If the System Error continues, replace the Service Station. If the System Error continues, replace the PrintMech PCA
Jul 27, 2010 | HP DesignJet Z2100 InkJet Photo Printer
HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
Corrective Action: Try the following:
�� Switch the Power OFF from the back of the Printer and disconnect the
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Sep 25, 2009 | HP Designjet Z6100 InkJet Printer
Light and dark banding on HP Designjet Z6100
this could be several issues. clean your encoder strip, clean the contacts on your printheads and carriage assembly. check that you are using the correct media profile. let me know if this helps.
kd
Aug 06, 2009 | HP Designjet Z6100 InkJet Printer
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
