Question about Dell Dimension 5100 (D51L1) PC Desktop
Computer won't start
I have a dell dimension 5100 desktop that was working fine yesterday. Today when I push the button to start up it does nothing. I have checked the power cord and it is fine. The surger protector is fine as the monitor and speakers are plugged into the same protector. Have also tried other outlets with same result. Any suggestions?
  • 3 more comments
  • azarmi Jan 01, 2008
    I got exactlyt he same problem with my DIM 5100, P4, 531. It was working just fine until today. As ususual, I pushed the power button, but it never turned green, Instead, a yellow light kept blinking and as a result he computer never got turned on. I openned it and looked inside; everything looks OK. Any assistance will be much appreciated.
  • Norvell389 Jan 01, 2008
    I have a dell dimension 4500. I push the power to turn it on, all i'm getting is the dell screen and nothing else. I've check everything inside, all is okay. Can anybody help?
    Les
  • Agildur Jan 05, 2008
    I have the same problem with my sisters computer.
    The PSU is working when i short-circuit two of the cables on the connector to the Motherboard, A green led is lighting when the power is plugged in. but it wont start. I have taken out and put in the ram again, and taken a look at the other components than may have been loose.
    The voltage into the house may have been flickering somewhat due to some high power electrical engines being run before we tried to start the computer.
    Could this be a cause, and if so, should the psu still be working?
    What is the led indicating?
    Thanks for any possible replies.
  • ascc Mar 20, 2008
    My Dell 5100 starts sometimes and not other times. If I take the usb keyboard & mouse out and replace it starts. The green mother board light is on. The clock also loses time. Any thoughts anyone ? ASC
  • compucaver Apr 03, 2008
    I have a Dimension 5100. I pulled out the Hard drive to back it up and then put it back in. Now it won't start. The PSU tests good with a tester. There is a green light on the motherboard. I pulled out the modem and unplugged the USB keyboard and mouse.It simply won't start. What the heck?
  • 4 Answers
Hi...I have a Dell Dimension 5100...I think to solve u guys problem, i think you should reboot the hardware plug into your motherboards...make sure everything is plug into *********** bored properly. Maybe the bios system might be confuse.
Posted on May 18, 2008
I unplugged power from computer, removed motherboard battery, after all excess power was gone... ie green light went out, I plugged power back in, got a fast flashing amber light on front of computer, pressed the power button once, and after about 1 to 2 minutes the system came on, of course the bios stuff was gone, as well as date and time, but seems motherboard is working fine, now I dont know what to do.... possible bad bios chip???
Posted on May 16, 2008
Hi my dell dimension 5100 decided that it want going to power up. I have the green light on the mother board. Everything is clean insode and tightened the best I can tell. IF you could give me any ideas that would be great. Thanks Holly
Posted on Dec 30, 2007
    Sergeant:
  • 239 Answers
Can you see a green light on located on the mother board ? I had the same problem with mine right after the warrranty was off, The mother board failed, But you should make sure thats it first by making sure everything Inside of the computer is tight and secure.Unplug and make sure there is no power on and unplugged,Before you touch anything inside your computer discharge any static electricity by touching the metal on the inside of the tower. The Memory modules Make sure that they are pushed in securely in there slots and video card is Pushed in and tight, and any other extras you may have plugged into it, After you do all that put everything back and try to reboot see if that get you up and going. If not let me know I can Help You fix it or repair it myself if you would like, just leave message here or email me. bear350cid@yahoo.com Happy Holidays
Posted on Dec 15, 2007
Help me, my Dell 2400 desktop worked fine yesterday, but today it will power on to boot start up but then i get nothing else on the screen, one green light only and no fan noise. i tried unplugging and...
from your explanation it like the problem come from your motherboard, your motherboard was damaged, and you need to change the motherboard with new one
Mar 25, 2011 | Dell Dimension 2400 PC Desktop
Dell Dimension C5100 Yesterday it was fine and today it turns on but no visual on the screen. Changed monitor that wasn't it, disconnected the video from the on board video output and installed a pci...
you need to open cpu cabinet. Open back cover of cpu then refix the RAM memory. Pull cmos cell from motherboard for 10 minutes then put it back then all settings defaults. Make sure RAM is working fine. Try with another RAM .If you use 2 RAM memory then check with only 1 RAM 1 by 1. Open processor fan and processor then put it back . Clean dust from all parts . Reconnect both connection to harddrive. Make sure motherboard don't touch the cabinet. Remove pci card if any reattach vga card if you use pci vga card.Pull cmos cell cell from motherboard for 10 minutes then reconnect it.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Sep 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
After start button is pushed several low buzzes is heard
Better check that power supply & where it plugs in at out. Also,make sure all the connections are plugged in tight inside. Never assume that a replaced part is good & if you went after-market for the power supply, don't go super cheap. Buy a good one with a good warranty & the same if not more juice than the original.
May 12, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Where do I find the eject key to eject a cd from my Dell studio laptop?
There should be a button on the DVD/CD drive itself, just push that small button and the tray should eject.
If you can't fine the button double click on "Computer" or "My Computer" highlight the DVD/CD in the list, right click on the DVD/CD and select "eject" from the list.
The tray should now eject.
Regards.
Jan 11, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I have a Dell Dimension 5100 Desktop that will not turn on.
hi...try to open side cover then find the memory then pull out and clean the pin connectors using Paper Eraser only..thanks...
May 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Feb 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 4600C won't turn on
Unplug the unit. Re-seat the Memory and Daughter-boards. Plug in and try to start.
Nov 22, 2008 | Dell Dimension 4600 PC Desktop
5100 problem
Hi
To help you troubleshoot a problem, your computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
Reply with the Power Button light and the Diagnostic lights color and sequence for further assistance.
Advanced Troubleshooting and Owner's Manual
Mike
May 30, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 Won't start up
Hi
First disconnecting the power cord and re-seat all connections (Keyboard, Mouse espercially). Connect up the power cord and try powering the PC.
To help you troubleshoot a problem, Dell Dimension 5100 has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel. When the computer starts normally, the lights flash. After the computer starts, all four lights display solid green. If the computer malfunctions, the color and sequence of the lights identify the problem.
If the computer failed to start up check the diagnostic lights color and sequence and Check the link below for more info (Assuming you have another system that can access internet)
http://support.dell.com/support/edocs/systems/dim5100/en/sm/tshoot1.htm#wp1120147
Alternatively, contact Dell Support with the diagnostic lights color and sequence to raise a service call if the system if under warranty.
Mike
Mar 31, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
300 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
