Question about Sewing Machines
How do you adjust the timing on 221 featherweight The hook is hitting the top of the throat plate.
  • sewtexas May 11, 2010
    you are not describing a timing problem, sounds like your needle plate is not installed with hook gid, small pc of metal the sticks up from hook, this pc must be in the slot in the neelde plate, when install needle plate this pc needs to be at 12 oclock
  • 980 Answers
Email for attachment of instructions drivewithken@blueyonder.co.uk
Posted on Sep 27, 2009
How do I set the bobbin on the singer featherweight so it does not hit he upper plate
Go to the Singer Sewing Machine Site, select Support, and there is an option to download your user's manual free. On page 7, it shows you how to insert both the bobbin and bobbin case.
I have seen many of these cases, and here is how they work. You'll notice a lever on the front of the case. When that lever is in, you can't remove the bobbin. When you need to insert the case, you have to lift the lever, making sure that the protrusion in the case is on top.
Feb 17, 2015 | Singer Featherweight 221 Bobbin Case,...
Serial numbers lookup
If it is a singer that model was made in 1948. The serial number says that the machine is a very desirable "Featherweight" model 221.
To make sure that it is a Singer Featherweight check to see if it has a fold up bed extension. Also there "221 or 221A" should be on the side in on a small brass plate.
If it is in fair condition it could be worth $200 to $400. The price depends on color and condition but even 221's in poor condition are very saleable.
Good Luck
Jul 17, 2014 | Singer Sewing Machines
My featherweight singer will not pick up thread in bobbin
The singer 221 needs to be threaded with the flat side of the needle on the left side. The thread passes through the eye of the needle from right to left. If this does not solve your problem it may be out of time. You can remove the needle plate and watch the hook it should pass above the eye of the needle as you turn the handwheel towards you. First you need to make sure the needle is at the correct height before adjusting the timing on the lower shaft. You may want to take this in for service if your timing is off.
May 14, 2014 | Sewing Machines
Bought a featherlite 221 will not pick up bobbin thread have no manaul so am i threading it correctly or putting in needle wrong the machine is like new
I see Singer Featherweight Featherlite manuals, not a Featherlite as a stand-alone model name. For the Featherweight 221 manual try here: http://www.singerco.com/accessories/manuals.html and enter the model 221. Alternative site: http://www.singer-featherweight.com/ with the direct link to the manual here: http://www.singer-featherweight.com/sitetwopages/singfea.pdf .
I hope this helps.
Apr 30, 2011 | Singer Sewing Machines
I have a singer featherweight, Serial number AL409402, I'm trying to find out if this is a model 221 by the serial number, can you tell me if it is?
Singer has on their web site with a database of their serial numbers. Since you have the serial number to your machine, it will be easy to find out.
Hope this helps.
Aug 10, 2010 | Singer Sewing Machines
My Featherweight 221 is ticking, ticking, ticking. It ticks with/or without the bobbin, needle or needle plate. What can I do? Kathy
Remove the bobbin case, put a drop of "sewing machine oil" into the area between where the outer shuttle is turning and the inner shuttle (the part that has the pin sticking out that the bobbin case fits onto.) Also check to see if there is a thread jam in that area. Do not remove or loosen any screws.
Feb 09, 2010 | Singer Featherweight II 117
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
I have a Singer Featherweight 221-1 that won't form a stitch
The needle goes in with the flat side on the left and you thread it from right to left ,hope this helps
Jan 10, 2009 | Singer Featherweight II 117
Singer featherweight 221 timeing is off
There is a web site/group called featherweights, maybe .com or .org
See if the moderator who seems to know whats what can help. I am also sure one of the techs here will know too.
Dec 18, 2007 | Sewing Machines
Sewing Machines Logo
53 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
