Question about Delta & Single Handle Shower Faucet
Need a diagram on how to disassemble a Delta 1900 series single handle shower diverter
    Scholar:
  • 44 Answers
I installed a single lever shower unit when water is turned on i water out of spout and shower head . i took it a part all washers look good and doubled checked unit was put on right to water lines
You should also have a diverter in the spout. Just turn the old spout off and turn the diverter spout on. You lift the ball on top to use the shower.
Dec 05, 2012 | Delta & Single Handle Shower Faucet
I have a delta tub shower faucet with a pull-out diverter. The model is "Delex" by Delta as stamped on the cover plates. I have not had any luck finding a replacement diverter. Neither Delta U.S...
take the details to a plumber supply shop ( where the tradies get their parts ) and discuss the problem with them
it is very possible that there are other makes that will fit in the holes to replace the delta unit
Mar 25, 2017 | Delta & Single Handle Shower Faucet
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Shower diverter push handle is squirting water out
If you are handy, the best solution is to call delta and have them send you a new diverter. They will need the model of your faucet. The new diverter will come with instructions on the install process. As far as fixing it without the new diverter, I don't believe you will be able to.
Nov 17, 2009 | Delta & Single Handle Shower Faucet
1 HANDLE TUB/SHOWER. WHEN YOU TURN THE SHOWER ON
The diverter is worn and needs to be replaced.
The diverter is the lever/button you pull/push to switch from shower to tub. When they get worn, they require more pressure to seal properly and divert the flow.
Aug 06, 2009 | Delta T13420 Chrome Classic Single Handle...
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Delta & Single Handle Shower Faucet  Logo
1,545 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
