Question about Traulsen Refrigerators
The refrigrator sution line keep's freezing and wont cool lower than 44 degee's. what should i do to get my temp down and keep the line from freezing? Also what should the high side pressure and low side pressure be?
  • 909 Answers
Im taking it that you have recently had work done on your fridge. What you are telling me is the system is overcharged by a fair amount. Decant by removing small amounts of gas from the service port which in effect "should still be on."Depress and Remove in 5 second intervals then stop and wait for approx 10 min. If ice is still there carry on that way untill ice is no longer on the suction line. If the evap. is flooded, cooling is lost. On the small compressors, do not worry about the high side pressure, you normally charge to -15 deg. celcius. at your ambiant temp. .
Posted on Sep 23, 2009
Samsung RB1955SW refrigerator error code -2 / 44
I think that is your temperature setting that you set it it or could be the temperature in the case
Feb 22, 2018 | Refrigerators
The control on the bottom freeser not working properly, the display number for the freezer is showing a temperature of 50 degee, where was at -4, now it is not freeze.
might need a new temp switch of you lost your freon wich will no longer cool like a ac in a car call a plumeing and heating guy to check ac level in the comprassor good luck
May 03, 2014 | Samsung RS2630SH Side by Side Refrigerator
Freezer temp is -4 and refrig is 38. Not sure if these are correct settings but water in freig bladder keeps freezing and can't get water. Warmed bladder twice to get water to come out. If freezer temp...
Sorry if you don't like this solution, it does not make it work correctly. But my water works all the time now.
We too had the water dispensor stopping due to freezing of water in the storage tank. A blow dryer and about 10 minutes later we could get it working again.
We tried different fridge temp settings , and according to a thermometer placed inside the fridge in various locations we are getting the fridge temps we want, so it is not runing too cold.
I tried insulating the storage tank and the lines, this did not work.
I removed the tank and just connected the two lines, this still did not work.
I finally just pulled the lines out of the fridge completely and connected them underneath the fridge so water runs from the valve at back straight to door. The plastic panel on bottom was a great place to store the lines. I drilled a hole to reroute the door line to this area . Line runs behind lower plastic cover on front . The water does not get cold, but it never stops flowing, this was more important to us. I did consider rerouting both lines to the top shelf and putting the storage tank back in to get colder water, but no one minds the way it works so I probably will not do this. I would have run them up the back to avoid the inside lower area of the fridge. In the long run I will avoid this brand and avoid "twin-cooling" completely. All my neighbors and friends who bought this type all had to throw them away as they were too dofficult and expensive to keep running.
Jan 15, 2011 | Samsung RS2534 Side by Side Refrigerator
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Neither Roof Air Works
Yes and no .. Freezing temps should not affect your A/C at all ... BUT .. there is a freeze control box, its called a control unit to prevent itself from freezing up and burning out, take down the lower cover and you will see it. Your problem is more likely to be more central since neither are working Thermostat or even the control box's in genera, even could be a freon problem if the cold weather was really bad and you could have a leak on your lines, check it out and see what you got!
Dec 31, 2008 | Dometic Rooftop RV Air Conditioner
My AC unit keeps freezing up on the copper lines going into the house from the outside unit. It also freezes up on the inside lines and the air is not cooling my home down.
Operate your air conditioner with the fan in the on position. But first turn the fan on, turn the temp up or shut the cooling off. Your coil is more than likely frozen over. At night when outside temperature drops the refrigerant pressure and temperature in the system also drops. This action can cause icing of the cooling coil, with the fan in automatic everything shuts down at the end of a cooling cycle. Thus no air movement to melt ice on previous cooling cycle.
May 09, 2008 | Heating & Cooling
Refrigerators Logo
253 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
