Question about Maytag MES5752BAS Stainless Steel Electric Kitchen Range
I need to know how much the range (Including handle) sticks out past the front of the cabinet?
    President:
  • 1,304 Answers
On a stnd 24 in depth cabinet and counter close to 3 inches should protrude unless you have the anit-tip installed then it could be up to 4
Posted on Oct 03, 2009
Lost dip stick (oil)
What motor? it varies. I did see that JC whiteny sells properly cut length ones for all the motors and they are pretty cheap
Oct 02, 2015 | 1990 Dodge Dakota
Handle loose on fratelli onofri royal chiantishire range
take off the whole door including the glass and possibly the lower shelf watch out for screws inside you can fix
Jun 19, 2012 | SNK Fratelli Onofri Royal Chiantishire...
We purchased a slide in range, Frigidaire fggs3045kf. We want to put a granite countertop and use tile on the floor. When we raise the heighth of the range to make room for the tile, the ridge of the...
Hello Mkoffice, this a very common problem when floors are installed in front of cabinets and not underthe cabinets. it also causes a problem for the dishwasher. it will become trapped or cant be installed.If you dont want to removed cabinets to install the tile. you will need to raise the cabinet height. my shop has run into this before. We add 1 inch tall strips of wood across the entire front edge of the cabinets. the same is done to the back wall and any area where two cabinets sides meet. we dont use full sheet of ply wood because the granite installers will need access into the top of the cabinets to level the counters. The wood type should match the cabinet.( at least in the front) it will have to be stained or painted.
Hope this helps
Joe Connolly
Aug 16, 2011 | Frigidaire FGGS3045KF Stainless Steel Gas...
Home Depot lists a depth dimension for a GE refrigerator. Is the handle included in the depth dimension?
no. depth is measured from the back of the box to the front of the box but does not include the handles. The depth of the cabinet is used to determine if the doors will open sufficiently to clear countertops and half walls or appliances. Also helps determine if enough space will be available to open doors in small kitchens such as "c" shape, "L" shape or narrow galley kitchens. for small kitchens, the best frig is a side by side. The doors are smaller and less swing space is needed. A 25 cubic foot side by side uses less swing space then a 15 cubic foot single door. If you are worried about depth, you can also get a counter depth frig which will stick out past your countertops by about 2 inches rather then 8-10 inches with a standard frig. standard depth is about 28-36 inches from the back wall when plugged in. Handles get in the way most often in width measurements because they prevent the doors from swinging past 90 degrees if located next to a wall.
Dec 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hello, I purchased a Kitchen Aid Architect II series KUDSO3FTPA3 ~ two years ago. It is deigned so you can put your own panel on it. Duw to a design issue with my cabinets I was not able to add my own...
There is a MUCH better way! go to www.applianceart.com, these guys have tons of panel options including stainless and fax stainless that was featured on HGTV and the Today Show. www.applianceart.com (Appliance Art)
Aug 28, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
How do I replace a burner control on a Whirlpool glass cooktop model GJD3044RB00? I know the control is bad, because the shaft came out of the control [left front]
Turn off circuit breaker to range. Remove the cooktop from the cabinet and tilt it to give access to the control. Remove the nut on the top holding the control in. Diagram wire connections, disconnect wires, install new control, connect wires to new control, put cooktop back into cabinet.
May need to prop up cooktop in tilt position to keep it in place while you work on it.
If you have trouble/question, let me know.
Charlie
Sep 30, 2009 | Whirlpool Kitchen Ranges
I am trying to replace my old slide in gas range (Magic Chef- model # 6498XTS with a new slide in gas range and am trying to find out if the new one will fit where the old stove was, here's my problem the...
The installation depths provided in the installation literature, are the minimum requirements for fitting the slide in range into place. You need to determine what the depth of your opening is where you intend to install the appliance. The depth shown on the installation instructions might be showing the overall depth of the appliance, including the oven door, which typically sticks out from the cabinet anywhere from 1-3 inches, depending on the brand, model, etc. The old Magic Chef might have only provided the needed depth for the oven body, and might not have included the front oven door projection, past the countertop, etc. Most cabinents are about 24 inches deep, so anything larger than that, will likely stick out into the room more, unless your cabinents are deeper than 24", you're looking at having the new slide in oven stick out past the front cabinet front/edge, by about 4 5/16". I'd make a cardboard template to the dimensions of the new oven and use that to see just what you're facing with the replacement oven. It could be possible that you've confused the depth with the width for the new oven, as I've not seen many ovens that are as large as 28" unless it was a Viking, or other really high end, professional style oven, etc. Check your installation dimensions again for the Maytag and make a cardboard template to confirm how much space will be needed. The good news is that you can remove the old Magic Chef, since it's not working, to allow you to make a more informed decision as to fit and clearances required for the new oven. Just be sure to disconnect the power to the range or unplug the power cord, if that's what it has, before attempting to remove the slide in. Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
How do i change a fuse in a kitchenaid overhead microwave
Hello,On the front of the microwave above the door is a louvered panel. You need to remove the panel ( usually it just pulls straight off ) and inside on the left you will see a metal rod that's bent 90 degrees. That is the lock handle. While lifting on the front of the microwave pull that handle out to release the lock. The front of the microwave will tilt down, you may have to help it start tipping. Once the microwave is tipped down you have to lift the back that is against the wall to unhook it from the wall mounting panel. Be careful to feed the power cord through the cabinet hole as your lowering it. Good luck and let me know how this works.
Jan 02, 2009 | KitchenAid KHHS179LSS Convection /...
Missing Panel, Handle & Manual
The Incognito series is made to have a cabinet panel installed on the front - as to blend in with the cabinets - no handle - no panel - cabinet front panel with the cabinet hardware attached
Nov 02, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Maytag MES5752BAS Stainless Steel Electric Kitchen Range Logo
78 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
