Question about Garmin nuvi 200W GPS Receiver
Unit goes into computer mode when I plug in the car charger lead. I go through the 'loading maps' screen, then the PIN screen, and it defaults to computer mode and I can't get any maps to show.
  • Garmin Master
  • 2,130 Answers
The rear mini-USB port is defective, making the unit think its connected to a PC. The port needs to be resoldered or replaced. Please see this link:
See the section about the PC icon.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Posted on Sep 24, 2009
I NEED TO UPDATE MAPS ONTO MY 1300 AND IM NOT SURE WHAT CABLE GOES INTO THE PORT ON MY SAT NAV
You connect your satnav to the computer with a mini USB lead. The narrow part, which is the same as the plug on the car charger, goes into the back of the satnav in the same socket that the car charger goes into. The USB connector goes into the USB port of the computer.
If you didn't get a mini USB lead with your satnav you might have one for another appliance that connects to your computer which would do the job. The same type of lead comes with most external hard drives and some camcorders and digital cameras. They are also sold in computer shops.
Jul 14, 2011 | GPS
When plugging into car outlet Garmin 200 goes into computer interface mode
You have to use a car charger with sufficient power capacity for your Nuvo 200.
I've used a mini USB car charger that came with my e-trex, but it works only some times when I do plug/unplugging during map loading (manipulating the computer mode setting). So, I bought a HTC mini USB care charger, and know the problem is solved. Another alternative is buy from Garmin Store, the type they recommend.
May 30, 2010 | Garmin nuvi 200 Car GPS Receiver
When switched on it goes into loading maps then switches off. Also if I put it onto charge it shows up what appears to be a computer and lead then sticks. ac
The icon that you are seeing means its in data mode, not charge mode, so your unit is never having the chance to charge because there are broken leads on the mini-usb jack on the back. You unit powers up, then goes off because the battery isnt charged.
The mini-usb connector needs repaired.
- Jim
Oct 16, 2009 | Garmin nuvi 250W GPS Receiver
I cannot use the GPS unit while in charge mode(NUVI 350)
Are you using a USB cable & charger to operate the GPS?
If so, you should stop and use the supplied cradle / power cord to power the GPS instead. The USB cable is used to transfer data to and from the GPS and on other models (maybe your 350, too) to slow charge the GPS battery when completely discharged. Powering with the USB cable will power up the GPS, but does not allow navigation, mapping, etc.
Oct 12, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Jun 08, 2009 | Garmin nuvi 200W GPS
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
I have a navman s90i . When i plug the car charger in the screen shows a compuyer runing into a navman via a cable then shuts down then try's to start but goes to the above screen
No solution but exactly the same model and exactly the same problem. When I put the car charger on the unit, it goes off and then comes back on and ust shows a computer as though the only option it can handle via usb is a computer connection. Interestingly, it still charges, but just becomes useless as a satnav as there are no maps, directions or any scree functionality at all.
Nov 22, 2008 | Navman GPS
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
Maestro 3250 Charging
I accidentally ran into this problem today when I inadvertantly plugged the wrong charger into the unit. I'm guessing that the device isn't getting the precise current it's expecting and thus thinks it's plugged into a computer. I'd suggest getting hold of a different charger and see if the problem goes away.
Jan 31, 2008 | Magellan Maestro 4040 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
1,387 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
