Question about Sharp Digital Imager AR-650 Black and White Copier
Where can i get a duplexer for the Sharp AR650?
Where can i get a duplexer part for a Sharp AR650?
  • lcook626 Sep 23, 2009
    Thank you. I did check eBay, but no possitive results. Will try Craigslist and check with my repairman.
    Scholar:
  • 95 Answers
Try eBay or Craigslist for a bargain, or contact your local Sharp Dealer in the yellow pages.
Posted on Sep 23, 2009
Testimonial: "Good advice, but nothing I did not known already. Very thankful for the response. Thank you."
My sharp ar650 is writing this firmware version up mode
Sound like a Copier operating system (Firmware issue) have a tech come out and look at it, as firmware is owned by Sharp not going to get it on line, normally available to dealerships and Sharp corp techs via secure server
Mar 05, 2015 | Sharp Office Equipment & Supplies
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
capacity.
2. Duplex setting is set for a single surface
model.
Apr 08, 2011 | Sharp AR-M205 Copier
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Jan 20, 2011 | Sharp AR-M237 Digital Copier
Have the Samsung DVD-AR650. When I insert a blank
My last recommendation, before seeking a replace or repair; would be to run a cleaner disk. Optical drives can be affected by dust on the optical block lens or dust on the disk itself. Sometimes a dirty lens can even cause your drive to eject the disk when you try to read it. It is recommended you clean your lens every 3 months in an office environment, or once a month if you use the drive in an industrial environment. They range in price from $3 to as high as $130. In such an
Jan 01, 2010 | Samsung DVD-AR650
How to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
Dec 14, 2009 | Sharp MX-2300N Color Copier
Sharp 5516 n legal duplex copying is not coming
Duplex unite only use a4 size not other size.You can try other size before configure.
Dec 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Duplex Set-up fro Sharp AR-M455N
does the machine have a duplex fitted? as it is an option for this machine either called a du3 or du4. It bolts onto the left hand side of the copier. On the lcd touchpanel you should see it sais 2 sided next to the output box, tap it and select 1 to 2 or 2 to 2 depending on your origonals.
Dec 05, 2008 | Sharp AR-M455N Copier
Duplex printer
Check the driver you have installed on your computer, that's where the duplexing would be generated from. You should be able to choose through print properties at this point. Here's the link to Sharp:
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Sep 10, 2008 | Sharp AR-507 Copier
Clock changing time
my clock keeps changing time, i have sent for repair to samsung.
they said they replaced the display . i still have the same problem .
i exchanged the dvd ar650 and this one is the same.
what the ? , i might have to change get rid of samsung and find something else.
any help since samsung can't fix thier product.
May 04, 2008 | Samsung DVD-AR650
Duplex not working on sharp ar-m207
Hi, i suspect duplex has been switched of in 'key operator programs', consult the manual to change this, or follow these instructions: press special functions, scroll down to 'key op prg', ok, enter 0000 (default number may of been changed), select copier, ok, scroll down to duplex, change to enable. Hope that helps
Andy
Jan 22, 2008 | Office Equipment & Supplies
Sharp Digital Imager  AR-650 Black and White Copier Logo
134 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
