Retired electrician Washer does not spin and stops. Please tell me what to do I can work on the machine and change parts if needed.
    President:
  • 1,776 Answers
The first thing that I would consider would be a defective lid switch. It can be tested for continuity using a multimeter or ohmmeter. A defective lid switch can cause this condition. I don't know what sort of washer you have, but check out the video at the following link and see if it helps you out. Sure hope so and sorry for your trouble. Best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 23, 2009
Maytag Epic Z Washing Machine shuts down during spin, can I fix it myself?
Hello Brain;
My name is Peter. I am a retired field service appliance technician.
Error codes are generalized. Both of your codes are drain relative. They will tell you to clean your drain, but there is more to it than that.
You may have a bad drain water level switch, a plugged drain line....
Please send me your model number, So I can see what your have.
Peter Goodwin
Glen Burnie, MD
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
Why is my Whirlpoo WFW9050X washer buzzing when it's turned on?
Biggest hassle with these machines is that the belt or drive stops working properly. Check for that first. If parts needed check here. Search Over 2 1 Million Appliance Parts
Sep 09, 2017 | Whirlpool WFW9050X Washer
Spin does has stopped working. all the functions work normally but the washer has stopped spinning.
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Here is a link to the part you will need.
Jan 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
'need wiring diagram for door latch on maytag performa model#pav2300. I have the part. Retired industrial electrician.
Not sure if this will paste here if not enter your model # at www.appliancehelponline.com the diagrams will come up on the right hand side.
May 03, 2010 | Maytag PAV2300 Top Load Washer
Spin cycle starts, speeds up, then stops spinning
This fault often occurs when something (like a small coin or a paper tissue) has blocked the drain pump!
The only way to fix this would be to get a service engineer to remove the pump and check for a blockage, unless of course you are an experienced electrician or technician and don't mind doing it yourself.
Nov 18, 2009 | GE WBSR3140DW Top Load Washer
Kenmore 70 series washer
Hi juanmapr,
The next step after checking the power would be to put the washer into the spin cycle and see if the machine will spin. This will tell you two things. 1 It will tell you that no water is coming in at the start of the wash cycle. 2. It will tell you if the rest of the parts are functioning properly.
If the machine will not spin when in the spin cycle and you do not hear the motor turning then you may have a bad timer.
If the machine will spin but when you start a wash cycle the water will not fill then you will need a new water inlet valve.
Please send me the model number and any other questions you may have if this does not fixYa and I can ship you any parts you may need for your repair. Or just let me know if you need a step by step how to do any repair, I am glad to help. Please dont forget to rate me.
Mike Anderson (Owner)
Anderson Appliance Repair
(865)945-3808
Oct 27, 2008 | Kenmore 24032\24036 Top Load Washer
Estate washer won't spin
If it still agitates and fills, this is most likely due to a faulty lid switch.
Oct 12, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Worn Barings on drum.
Bearing kits for your washer can be found here: http://www.ciao.co.uk/sr/q-hotpoint+wma
And as far as I can tell, there are no specialized tools required.
Mar 22, 2008 | Hotpoint WMA48 Front Load Washer
Washer won't stop spinning
i am a recently retired appliance engineer of 20 years, if the fault is not right after he has called then write to the manager of the company, if he is sole operator then write to him, explaining it like you said above, ask that the engineer stay and watch till the very end of the cycle as thats where the fault is, if he has already worked on the machine fetch them back? alternatively just ask a different engineer who knows what he is on about, to me this sounds like a circuit board problem either the timer or main pcb module, i presume this is a computer control washer with a digital display, hope this has helped you at least as to where to start, thank you.
Sep 13, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
