Question about Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower
Need timming specks & torgue speck for rod bolts
  • 389 Answers
There are no timing "specs", if the flywheel key is good and the magneto air gap is properly set, the timing will be right.
Torque for the rod bolts is 45 INCH pounds - NOTE INCH pounds not foot pounds
Posted on Sep 23, 2009
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
1997 3.3l dodge grand caravan rod cap torque speck's
My info shows two steps for rod bolts. 1st--40 ft lbs, 2--additional 1/4 turn.
May 17, 2015 | 1997 Dodge Grand Caravan
Engine bolt torque settings
Should be torque specks in the workshop manual.
Jul 28, 2014 | 1997 Buick Riviera
I have a speck 90 series pump with a broken impeller how do i remove the impeller off the shaft
You'll need to remove the back plate off the motor. Take a pair of channel locks and hold onto the bolt that goes through the motor. With your other hand, unscrew the impeller off the shaft.
Jun 14, 2011 | Speck Pumps Pool & Spa
Need to know crankshaft main bearings and rod bearings torque specks.
2 Different size engines for that year. If you have the 2.2 the main bearing caps are 70 ft/lbs (final torque) & the rod bearing caps are 38 ft/lbs (final torque). If you have the 4.3, the main bearing caps are 77 ft/lbs (final torque) & the rod bearing caps are 45 ft/lbs (final torque). I hope this helps and good luck.
Mar 13, 2011 | 1996 Chevrolet S-10 Pickup
I need bolt torque specs for a 2006 chevy cobalt Rod bolt and pan bolt torque specs also oil clearance for rod journals
if you just go to a mecanic and ask what are the specks on that they should know but i think if you just tighten them down with an impact wrench till it is really tight after ou start the car it will run like **** then it will work its self out
Nov 17, 2009 | 2006 Chevrolet Cobalt
Torque specks
hi 1999 chevy malibu head bolts 1-8 40 ft lbs bolts9-10 30 ft lbs tighten all bolts an additional 90 degrees
rod bearings 18 ft lbs plus additional 80 degrees
head
top row of bolts 9 3 1 5 7 bottom row 10 6 2 4 8 from left to right
Feb 12, 2009 | 1999 Chevrolet Malibu
Tourque specks
Good day;
Is it the rod connecting cap you talking about if so here is the specs 89 lbs (120 N.m) If this it not you are looking for please let me know.
Cheers.
Aug 13, 2008 | 2000 Ford Focus
Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP  Gas Powered Lawn Mower  Logo
270 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
