19" ITV Flat Panel LCD
I have a ITV 19" that will power up and then shut off. I will not stay on. need help
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Jayon, Need more information!!! Did unit work "perfectly" day before? What did you SEE on the screen when you pushed the on/off buton? How many hours of use does this unit have on it? Is there a blinking LED power indicator on the front panel? Does unit hav sound or no sound? Does screen go completely BLACK? This symptom you have described leads me to think that the unit's SMPS/inverter power supply is going into "SHUTDOWN" mode to save itself from self destruction!!! You will need a Tech to look at it and try to effect a repair. There's not a lot of options you have open to you at this time. If you feel brave enough to try to do a close visual inspection of the switch-mode-power-supply and inverter supply on your own, get back to me. You will also need to do some research on the web for information such as "bad capacitors", "cold-cathode-fluorescent-tube replacement", "switch-mode-power-supply" repair and or "LCD monitor repair and or recapping" You also need to view monitor disassembly video clips on youtube to familarize yourself with what is inside a typical LCD monitor/TV. But that's only if your technically inclined. I'm louis12fix on fixya or lmistyrel @aol.com
Bye for now.
Posted on Sep 23, 2009
How do i get channels to set
Don't understand the Question, The channels are your Camera's
Jul 14, 2012 | Samsung SMT-190 19" Flat Panel TFT LCD...
Sharp tv opc light stays on
I have an opc light that stays on. My cable channel input will come on briefly then picture and sound shut off but the dvr works just fine.
May 01, 2011 | Sharp LC-19SB25U 19 in. LCD HDTV
Lg LCD monitor turns off after 5 seconds
Does it stay on when you plug it in IF the serial cable is not connected? Ours would come on and display "connect cable"...then when we did, it would shut off. Turns out it had a bad capacitor on the power board. Cost $1.25 to replace the part.
Sep 16, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
My tv has power the red light stays on and when it does work it some times shuts off while watching it.
Looks like there's some loose contact on ur main board. Its called cold joints ( solder joints ) Get a tech to have it checked to resolder it or if ure good at it then resolder the parts carefully without touching other components. Update here if these helps.
Nov 24, 2009 | Dynex 19 in. LCD Flat-Panel HDTV
Power Shut off today and my Sharp LCD TV no longer works any way i can repair it im a DIY
i'd be checking the fuse
then i'd be checking for **** inside like dirt and dust build up
Aug 06, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Monitor will not stay on
I am having the same issue. Stays on for 2 seconds then goes black. If I find a solution I'll let you know.
Apr 07, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
Dec 31, 2008 | LG 32LX1D 32 in. LCD Television
I've got exaclty the same problem :-/
HELP!
Oct 06, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
I have the same problem, can anybody help?
Jun 15, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
HP F1903 FLAT PANEL POWER PROBLEMS
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
