Question about Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder
Powers off When I try to play back a tape of something I've recorded, the camera shuts off. The rewind engages, then nothing, then the unit shuts off. Is it hopeless?
  • JAGM Dec 16, 2007
    Thank you.
  • 169 Answers
The capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera...
Posted on Dec 16, 2007
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
Magnavox ZV450MW8 shuts off when trying to rewind.
Unplug the machine and pick it up and shake it, this will tell you if something is in there that shouldn't be or that something broke off.
So many things could be wrong that it is probably not worth fixing if it is not a foreign object inside.
May 15, 2014 | Magnavox ZV450MW8 DVD Recorder VCR
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
When playback of tape, fuzzy, not clear picture, or blue screen with sounds
try rewinding the tape and play it from the beginning.if still the same,video heads may be dirty and needs to be clean.i recommend you use a dry head cleaning tape.after which reinsert tape and play it again.if issue persists use a diff tape with previous recordings.if still no go,use new tape and try recording on it,play it back and check.if still the same your unit will require service.thanks:) hope this help.
Mar 12, 2010 | Sony Handycam CCD-TRV308 Camcorder
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
Has error
It's a supply reel fault. I kid you not, the cure is to give it a REASONABLY FORCEFUL open-handed slap on the tape side. it may take a couple of tries but it works about 95% of the time.
Dec 03, 2007 | Sony Handycam CCD-TRV308 Camcorder
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Will not play back
Usually if there is no impact injury involved or nagging intermittent past problems, you probably have a head cleaning issue. Try a dry type (reccomended) cleaning tape. Should be able to purchase at Best Buy or similar store. Good luck, magic seadog
Jun 10, 2007 | JVC Cybercam GR-DVL805 Mini DV Digital...
Has error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Dec 24, 2006 | Sony Handycam CCD-TRV308 Camcorder
All of a sudden some of my tapes will not playback and others will??
I have been experiencing the same problem with my Panasonic PV-GS120. I don't know the root cause or real solution, but I found if I keep playing the tape, rewind->play->rewind->play, eventually I would get the image back normal. I think I would try to clean up header with a header cleaner to see if it helps or not. If not, I plan to submit a request to Panasonic support to check out possible solution. Good luck.
Oct 22, 2006 | Panasonic Palmcorder PV-GS120 Mini DV...
Panasonic Palmcorder PV-DV102 Mini DV Digital Camcorder Logo
118 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
