Question about Vacuums
I need to purchase brush roll and brush strips for Beam Rugmaster bm1393. Where can I order them? Thank you Jeff
    Scholar:
  • 112 Answers
Here is a link to where you can purchase the part.
http://www.mountaincentralvac.com/products/prodDetails.asp?pID=224
Posted on Sep 23, 2009
Shark nv350 making loud noise when switched for carpet
HI, it's Jim from Crucial Vacuum!
If your Shark NV350 vacuum is making loud noises when switched to carpet then there are a few parts of your vacuum you can check to resolve the problem.
First thing let's check your vacuums canister. The idea is to prevent clogs and anything that will obstruct your vacuum from operating properly, and running smoothly without noise. You'll want to empty your canister after every use.
Secondly, let's check out your brush roll. Is there hair wrapped around the roll itself, or any noticeable debris that would prevent the brush roll from turning? If so remove it and manually rotate the brush roll to help unearth any hidden clogs behind the roll.
While you're examining your vacuums brush roll take a look at the belt as well. If the belt isn't wrapped around the brush roll properly this could be causing the noise. The belt should have a good bit of tension on it in order for the brush roll to turn properly. Your vacuums belt should be replaced roughly every 3 months. So be sure it's on properly and has a good bit of tension.
You can purchase replacement parts for your Shark NV350 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV350&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim
Crucial Vacuum Customer Care
Mar 19, 2015 | Shark Navigator Lift-Away NV350
Beam BM1386 AB need to change belt but can't find manual
Not familiar with the beam model but they are all the same. Take off the shield that is covering the beater brush and you will see the groove and the diver motor where the belt was. Slide it on and put the cover back on and you are done.
Aug 04, 2014 | Beam Rugmaster BM1386AB Belt
Change belt
flip it upside down , undo 2 phillips screws, flip top up and off from the back, lift out roller , replace belt , stretch back in place , put top back on starting with front lip, then put in screws
Apr 25, 2013 | Beam Rugmaster Plus Belt
The electric powerhead for my Beam Central vac shakes or vibrates as I vacuum.Cannot find an obvious problem. Brush strips are not worn.
The brush roller itself may be warped, or the bearings may be starting to wear out.
Replacing the brush roller may solve the entire problem.
Good luck.
Mark
Nov 09, 2010 | Beam Industries Vacuums
I have a Beam Rugmaster Plus power head Model BM1 393 Type AB and the connection were the metal pipe meets the plastic swivel broke close to the unit. It appears like a manufacture defect in that is broke...
This is most likely repairable. Lots of the Beam parts are available. I would recommend checking out any local vacuum shop or searching online for a central vacuum store that sells beam products.
Sep 29, 2009 | Beam Industries 750 Classic Bagless...
How to replace Simplicity vac brush roll strips?
The caps will come out of the end of the metal roller. They can be difficult if it's been a long time as dirt and grime can build up. Try sticking a flat head screwdriver in and gently twisting to get the caps to slide out.
Jul 16, 2009 | Riccar Vacuums
Kirby Ultimate G Series Diamond Edition
Take a look at the help article here. If bristles are worn you may need to install the brush roll in a different position (details HERE) or purchase a new brush roll.
Good Luck
Rocky
Jan 03, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Can not find a new brush
You should be able to order thru a repair shop, you will need your model number. Are you talking about the brush roll or an attachment brush?
Jan 05, 2008 | Panasonic MC-V7720 Bagless Upright Vacuum
Vacuums Logo
43 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
