Question about Broan-NuTone (668RP) Fan
Trying to uninstall a Nutone 8663NLP ceiling fan/light. Seems to be attached to joist on one side. Can't seem to budge. How to do it?
    President:
  • 704 Answers
Hi, Yes the fan box enclosure is either nailed or screwed to the joist on one end. Typically, the enclosure has a couple (2) mounting tabs that extend past the ends of the metal box about 1 inches. That is where the fasteners (either nails or screws) that mount the box to the joist.
The easiest way to get the fan off, without tearing up the ceiling drywall, etc. is to use either a hacksaw blade in a handle that lets you extend the blade past the tool so you can saw through the fasteners on each side.
The other option is to use a Reciprocating electric saw (Sawzall type) with a bi-metal blade to do the same thing, cut through the fasteners.
My advice for both ways to cut off the nails or screws, is to put the saw straight up with the blade facing in towards the fan enclosure at an angle of about 30-45 degrees so you're cutting inwards, toward the rest of the fan.
By doing the cutting this way, if you should happen to slip, you won't risk cutting into the ceiling outside the fan/light opening. Just a little trick to save on drywall repairs to minimize the chance of damage.
Make sure that the power is off to the fan/light before trying to remove the enclosure so you don't have to worry about nicking the wires above the ceiling while removing the metal enclosure.
Hope you find this Very Helpful and best regards!
Posted on Sep 23, 2009
Ceiling fan not working. How do I remove the fan to see if the vent is clogged?
Usually the cover pulls down, and is suspended on wires.
Push together the wires to release cover.
Use vacuum to clean.
Dissemble using screwdriver if possible. Some newer fans are one-piece and cannot be taken apart.
See if fan turns on.
Open wire cover and inspect wires.
Use non-contact tester to see if unit has power when switch is turned on.
See if switch is good.
If fan does not turn on, then wires are loose, switch is bad, fan motor is bad.
Some fan motors are sold separately, and some are not, and whole unit has to be removed from between the joists, and new fan installed.
Dec 05, 2011 | Broan-NuTone Nutone 70 CFM Deluxe Ceiling...
My flush ceiling fan is wobbling and hitting against the ceiling making an awful noise. How do I fix that issue?
The fan blades appear to be out of balance. First, check the screws that hold the fan blade irons to the fan motor. Tighten all that may be loose. If that doesn't solve the problem. the fan hanger bracket behind the ceiling cowl cover may be loose (it's attached with thin screws). In addition, the electrical box, that the hanger is attached to, may have come loose from the ceiling joist. If the electrical box has come loose, the box will need to be reattached to the joist with 1 1/2" long screws.
Hope this helps to solve the problem.
Mar 14, 2011 | Heating & Cooling
How do I remove my old Broan ceiling fan/heater/light from my first floor bathroon?
Hello, W/D here.
Easy to do. In looking at your model, I found an upgrade kit for your model that doesn't require removal of the fan case, so this might be something else to consider. Here's the link for the upgrade:
http://www.broan.com/display/router.asp?ProductID=100402
But, you asked how to remove the fan:
First, make sure that the breaker controlling the power to the fan is off. Turn the fan switch to off. Remove the outer cover; it pulls down on two spring clips. Squeeze the clips to remove them from the slots and lay aside. Unplug the fan. In the corner behind a sheet metal cover are the wiring connections. Unwire the fan. Locate the screws holding the fan to the ceiling. There are a variety of ways to mount the fan, so the screws may be on the side, holding it to a joist, or they may be in the upper part of the casing, mounting the fan to a cross brace. Lower the fan down, threading the wiring out of the cavity. It may pass through a wire clamp, so this may have to be loosened first. As the fan comes out of the hole, disconnect the duct attached to the housing.
Best regards, --W/D--
Please rate our solutions so that we may continue to help others.
Feb 22, 2011 | Broan-NuTone N671 Nautilus Ceiling Fan
I have a Nu Tone LS80SE bath fan that died. It is an obsolete fan with no more support. Is there a current fan replacement that doesn't require major modifications to my duct already in place? I just...
I had the LS-80SE and it appears that that model is discontinued, including the replacement motor. I ended up replacing it with the QTN110E, which is a bit bigger. The QTN is designed to mount to a joist on the opposite side of the LS model, I avoided having to do that by just screwing through the metal body into the joist that the LS was mounted to instead of using the mounting holes that are provided on the QTN. You will end up having to remove a small amount of drywall approx 1"x 11.5" to fit the QTN in. Put a backing strip or piece of plywood up and behind the drywall so that you have something to screw the filler piece of drywall in to when you do your repair, mud the cracks, sand, texture if need be... hope that helps
Feb 22, 2011 | Broan-NuTone Nutone LS80 Ultra-QuieTTest...
After installation the whole fan wobbles. it is standard installation
The most important thing about installing a ceiling fan is to use the proper ceiling box, one that is approved and very firmly fastened to the ceiling joists. If this is not done and the fan is only attached to an existing ceiling box, it may end up being out of balance and wobbling, not to mention being very dangerous.
Sep 08, 2010 | Hunter 20479 The Stratford II Ceiling Fan
We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Jul 12, 2010 | Broan-NuTone N-763RLN Combination Light...
I need to install a ceiling fan in a room where there is no lighting fixture, only a switch that controls floor lamps
If you have wiring experience it can be done, if not I recommend picking up a do-it-yourself wiring book from home depot or other home improvement store. To make your job easy you can run your fan and the floor lamps off that switch as the fan does not use that much power. You will also need access about the ceiling to put up a fan box to hold the fan otherwise you need to pull some ceiling down; enough to go from joist to joist to put in the box. The fan box you need to get is a Westinghouse fan box capable of holding at least 50lbs. Then all you need to do is run your wires and attach your fan.
Apr 22, 2010 | Hunter 52" Ceiling Fan With Light And...
How do I replace the bulb in my Nutone Model 8663rp. the grill does not seem to come off.
It will, you just need to pull harder! Seriously. The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
Nov 11, 2009 | Broan-NuTone N-8663RP Combination Light...
Need to change light on old nutone heater
If there are no visible screws and no knob in the middle of the grate to unscrew you have a model which simply pulls down. If it has been up there for a while it may have been painted over so you will have to use a razor blade knife to cut through the paint around the perimeter. Once that is done, use a putty knife to carefully pry the grate away from the ceiling about one inch at a time, working your way around from side to side.
May 17, 2009 | Broan-NuTone N671 Nautilus Ceiling Fan
Noisey 8 x8 Broan Bathroom Exhaust Fan (With Light) (7 years old)
Mine was doing the same thing. I found it was coated with dust.
I took the blower out [unplugged it, and removed the single screw holding it to the box], took the face plate off [removed 4 or five screws] brushed the squirrel-cage fan blades using a narrow, long and stiff bristled brush, and reassembled it [used care to align the small plastic axle on the flap valve ] and reinstalled it. The vibration was greatly lessened and the fan was about as quiet as it had ever been.
Dec 23, 2008 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Broan-NuTone (668RP) Fan Logo
354 people viewed this question
Top Broan-NuTone Dryers Experts
Mike Squire
Craig Dupler
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
