Question about Garden
I have a Weedeater FL1500 which needs new fuel lines but I am not sure how to attatch new lines to the three parts found in tank.
3 Suggested Answers
bbreton
  • 437 Answers
SOURCE: I have a Weedeater FL1500 Blower. The fuel line
Find a shop that can do a compression test on the engine. If the compression is not at least 100 psi, the engine will not run. So replacing the fuel lines and filter will be money out the window. It may be time to buy a new one. Spend two to three times what you spent on this unit and you may have something a little better. I like Echo products myself but you have to buy them from a dealer to get a good unit.
Posted on Sep 24, 2009
#1 Taper
  • 1040 Answers
SOURCE: weedeater leaf blower FL1500
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray withcarb.cleaner.Make sure the small screen is free of debris. (Should beable to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
I need to repair the starter mechanizum on my weedeater fl1500 gas blower. How do you get at it?
Oh, are you in for a job.
here we go,,,,pull air output tube. then remove bottom of air intake shroud...then remove impellar, then remove top half of air intake shorud... now all starting parts will be visable. They are mounted on top of the top half of the air intake shorud......careful, the fuel tank is mounted to the top half of the shroud...Good luck.
May 29, 2010 | Weedeater 2 Speed Gas Blower FL1500LE ()
I have a Weedeater FL1500. I just changed the
Once it heats up either the spark plug or the ignition module is breaking causing them not to work. I would first check on the price of the ignition module, Then decide it is to expensive to repair and send it to the scrap man.
Good Day.
Oct 30, 2009 | Poulan Featherlite Gas Blower, with Low...
I have a 25cc weedeater leaf blower that will not idle. I found that the fuel line broke off at the filter inside the tank. Do I need to replace the line and filter or the tank assembly?
Order a new fuel filter and fit it on the existing line...unless the line is brittle and breaks easy in which case you would replace the line. The fuel lines pass through the tank and are fairly easy to replace plus they ahve the added advantage of being cheaper than a new fuel tank.
Oct 19, 2009 | Garden
Weedeater leaf blower FL1500
Just let me know.
Jim
I have a Weedeater FL1500 Blower. The fuel line has rotted. Inside the tank there was a filter, a small white fitting with two ends and a small rubber green wedge piece. I am not sure how to attatch the...
Sep 24, 2009 | Poulan Garden
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Sep 09, 2009 | Garden
Weedeater XT 85T trimmer fuel lines rotted
it's in the fuel tank it goes from the carburator into the fuel tank and replace the fuel filter while you have the tank off.
Jun 21, 2009 | Garden
Garden Logo
190 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
