Have a compaq presario sr1103wm ,when i try to boot up the power led just blinks green also the led for the dvd rom led blinks green and the tray won't open. i swapped out the power supply and it did the same thing.could it be the motherboard? thanks in advance for your help
    Brigadier General:
  • 7,191 Answers
Since the Power led on your system is blinking green, it is most probably a malfunctioning Power supply and it must be replaced with a new unit having the same specifications.
Also, perform the following steps to restore the power and to rule out other hardware failure:
1) Disconnect all the connections and the power cord from the PC
2) With the power cord disconnected, press and hold the power button on the front of PC for 5 seconds.
3) Plug in the power cord and test to see if the PC can turn on or not.
Please reply with the findings.
Hope this solves your problem. Thanks
Posted on Sep 23, 2009
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Looking where i can find the restore disk for a HP Compaq Presario SR1103WM please help me
Telephone HP, and order a set of the "System Restore" CD-ROM disks.
Probably about $20, plus $20 for overnight-courier delivery.
Apr 10, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Trying to restore my computer back to factory defaults without recovery disk
You can press F10 and you will get the option to take the computer to system console and then follow the steps and if you have the CD with you then follow the steps below
1 Shut down your computer and restart it. Watch for the Compaq logo, then press the "F1" key to enter setup.
2 Press the right arrow within setup to go to the Boot menu. Press the down arrow to access the "Boot Device Priority" option. Change the first boot device to CD-ROM by pressing the down arrow until "CD-ROM" is displayed.
3 Eject the CD tray and place the recovery CD that came with your computer into the tray. If you do not have a recovery CD, you can order one directly from Hewlett Packard.
4 Shut down and restart the computer. The Presario will automatically boot from the CD and begin the recovery process.
5 Select the operating system your computer shipped with. Many Compaq recovery CDs support multiple operating systems, so be sure to choose the operating system your computer shipped with.
6 Insert the operating system CD when prompted. Enter the license key for the operating system when prompted. The license key is typically found on a small tag located on the top or side of the computer.
Jan 02, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Hi I'm Tony from the Philippines and I have a Compaq presario f756nr notebook pc (to be exact), i want to reformat my laptop and the problem i am facing now is that when i try to use my cd/dvd rom drive to...
Hi Tony,
Thanks for the details you have mentioned. The steps you have taken are correct and if the System/ hardware is ok, it should boot from CD Drive. Whenever i have faced such an issue, i always started afresh to check each hardware (CD, DVD, ROM, Hard Disk, Cables, Connections etc) and most of the times the issue was optical drive or CD/DVDs.
So, I recommend that make sure that the CD/DVD ROM is functioning properly. When the system is set to boot from CD/DVD, it must try to read CD/DVD after power on. It is indicated by spinning of the optical drive and blinking CD ROM LED. If there is a bootable CD in the drive, it should boot. You may try to boot the system through DOS bootable CD. Also, if you still have the OS on your system, you may check the CD ROM through windows.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 09, 2010 | HP Compaq Presario F756NR Notebook
My Compaq Presario SR1103wm doesn't have cd-rom insalled. Or so the system tells me,I believe it because I can't get it to read one single disk.How do I install it?
If your not familiar with the insides of your cpu. You can purchase an external cd/dvd/rw drive and hook it up. usually with a usb or supplied cable. To install depending on type and brand just follow the instruction that come with it. They do work very well.
Oct 08, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
The cd tray on my compaq presario desktop wont close
The drive should be replaced. they are fairly cheap (like under 50 bucks) and simple to install. sorry about your untimely issue
please rate
Mar 03, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Blank screen and no lights on keyboard and mouse
*check the power cables
*check the power outlet
*check smps is fine
*check power switches are properly connected
*check in bios hdd is enabled
*open the case wheather the connections are properly connected
Jun 27, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Compaq presario dvd writer light blinking, dvd not working
check if power jack working right. Try to change it with other jack. Sometimes the pins inside jack are loose. try to tight them.
May 12, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
jasbo
jasbo
