Question about SanDisk Sansa e250 MP3 Player
My sansa 2gb went dead now it wont charge @ all
  • 400 Answers
It's either problem with the player or the charger if you usually charge it when you connect to the computer then it's more likely to be a problem on the player itself and it will have to be replaced ,if it has warranty then return it.
You can also try a different USB cable or USB port.
Posted on Sep 23, 2009
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa sandisk mp3 2gb, wont charge
Sansa San disk 250 2GB doesn't charge via computer but change the AAA battery in the back.
Sep 26, 2009 | SanDisk Sansa m250 MP3 Player
Sansa fuze 2gb wont turn on or charge
Mine did the exact same thing, (Even the going to bed thing) I'm glad you posted your question. Incidentally enough after trying to turn-off and on for ten minutes, I pressed all the buttons a whole bunch to show it my frustration.....then it worked. (?) I don't know why, but I think that the computer going into hibernation or shutting off affected it.
Jun 23, 2009 | SanDisk Sansa Fuze MP3 Player
Mp3 2gb sansa veiw wont turn on... but charge screen will show up
it seems that your player are corrupted.
it means some of your file are infected with virus and corrupted.
if you can try to reformat your player i suggest you to do it.
be aware that if you will going to reformat all files saved are possible to be deleted.
thanks,
Jun 01, 2009 | SanDisk Sansa Fuze MP3 Player
Sansa e200 2gb is countinously restarting
OK TRY THIS...Turn unit on and allow to completely run dead.Allow to fully charge.this should reset and no more constant reboot.Please allow to fully charge.Do not rush this process.RICHARDM69
Jan 07, 2009 | SanDisk Sansa e200 MP3 Player
Sansa Clip 2GB
yu charge it erveryday, and yuve been using it everyday, so that means that it needs to charge, if it says connected tocomp and charging that means that it needs more electricity in its battery to keep, its battery running.
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk, 2 GB Sansa mp3 player won't charge
I was having the same problem with my Sansa e250. My wife has the e200, and we didn't have any problems with that. I saw that someone on here suggested to lock the mp3 player with the tiny metal switch on top, so I did, and the battery charging icon on the bottom of the screen came on and stayed on, and the mp3 player worked. thanks!
Because of this I would suggest checking to see if it's locked or unlocked and then change it to charge it.
Jan 16, 2008 | SanDisk Sansa m250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
103 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
