Question about Tascam 202MKIII Single Dual Cassette Deck
Have a low hum in my tascam 202km111 cassette mply unit
Esab Powercut 1300 error 13 open circuit voltage. how to fix that
These are not real good mechanism and I don't understand the complaint- there are no error codes in such a unit- I have one here now.
Apr 23, 2014 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Tascam 122MKIII Cassette player/recorder is malfunctioning.
I have one here at my shop that does the same thing almost. I found a gear broken in the mechanism system. The flashing LEDs tells you that the system control IC can not get the transport where it is suppose to go. The Gear C as described in the manual was the problem in the deck here. The head base was in the up position in this unit and thus would not eject. My E mail is skywavebe@sbcglobal.net. Due to the amount of dis-assembly to get to the transport control section this might be a job for a technician.
Feb 22, 2013 | Tascam Audio Players & Recorders
My Play, Pause, and Record button will continuously blink on and off, which prevents me from opening the cassette door using the eject button to play a tape.
That would be me at Skywave Tape Deck Repair- maybe I have contacted you already through Thumbtack.
I can not say more here but if you search for tape deck repair in Chicago you no doubt will come across me sooner or later.
The only other person you would be qualified would be Russ Bachmann at New Jersey Factory service. We both worked at Teac factory service facilities and rose to high ranks at those facilities.
Jan 18, 2013 | Tascam 122MKIII Single Dual Cassette Deck
Need belts for tascam 102 mk2 cassette player
This is easy to take care of just contact Marrs Communications and select the
Supreme" CASSETTE KIT $19.95
http://marrscommunications.com/tascam-cassette-kits
Oct 11, 2011 | Tascam 102 MKII Single Dual Cassette Deck
Need capstan belt for reel to reel -tascam-dx-44,pls help.
The model is not a DX44 as that is a dBx unit attached to either a Tascam 44 or 40-4. The tape deck model would need to be determined and when that is done go to Marrs Communications and order the belt kit for that machine and you will get the capstan and counter belt.
Oct 09, 2010 | Tascam Audio Players & Recorders
Tascam 644 When I press play it won''t stay on play, it stops. It will rewind and fast forward but that too stops by itself.
Scott has a point. You need to determine what is causing the unit to stop and it could be a bad cam motor belt if it has one or the lack of take-up die to the bad idler or even a dead spot on the reel motor. The reel motor will work normally at high speeds due to inertia but at low speeds as are used in play the dead spot of the motor can become much more apparent.
Sep 17, 2010 | Tascam 122MKIII Single Dual Cassette Deck
I have low volume and a distinct hum when playing a cassette using my RCA output line
How can an Idler have anything to do with audio hum?
You may have a bad cap in the preamp section, you can have a bad ground in a power supply screw or even a head wire that has broken off- a Technician should be able to locate the problem pretty fast.
Jun 14, 2010 | Tascam 122MKIII Single Dual Cassette Deck
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Tascam 102 mark 2 cassette
there is a mechanical problem in your tape deck. probably a losen rubber band. it clicks because the rubber is too lose to move the mechinal parts. so when you power off, it losen the whole machanical parts..it is very easy to replace..opend the deck and check it out..good luck
Apr 13, 2007 | Tascam 102 MKII Single Dual Cassette Deck
Tascam 202MKIII Single Dual Cassette Deck Logo
59 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
