Question about Fellowes Powershred 220CC Shredder
Our fellowes powershredder 220cc blade is not as sharp as before. in your opinion, do we need to replace the blade or it just need resharpening?
    President:
  • 3,085 Answers
No spare parts are available, you need a new shredder.
Posted on Sep 24, 2009
Fellows powershread keeps turning off - says bin is full when its empty
a known problem on these models. however, first make sure the sensors are clean and not covered with paper dust. they are located above top of basket with one on right and one on left side of basket. alos, if you have shredded paper hanging down, that will trigger sensors also. if everything looks good, you'll have to have sensors replaced.
hth,
razors
Jun 29, 2011 | Fellowes Powershred 220CC Shredder
Fellowes Powershredder, making clunking noise and ceases to shred
2 probably causes
to check this 1st unplug the machine
now take the top off ,there are 2 screws underneath the front edge of the cover assessable when the door is open, and 2 on the back you will want to back the shreddr up to a table when you take off the top (the sensors and switches are all still connected so this takes the stress off of the wires)
now you will need to remove the blade guards there are screws at the left and right ends of the guards,
once these are removed you should have a pretty good view of the blades, look for any visible obstruction (part of a binder clip or paper clip or metal closure from an envelope for example)
if this wasn't the cause try this
on the side of the blades there is a fan wheel that is connected to the motor. When you turn the fan with your hand you can manually turn the blades, typically you will be able to turn it to a given point and then it will be increasingly hard to turn, you might also notice that the bar on the outer edge of the blades begins to bend at this point. These bars seem to break under fairly low stress and having one break will also produce the symptoms you described. replacing one of those is a costly repair, (cost is largely because it is very time consuming,)
Jul 08, 2010 | Fellowes 220 Powershred Strip-Cut Shredder...
Not completely shredding. one side only makes
need bearing plate call cooks mobileshredding inc. or email cooksmobileshred@bellsouth.net or call bill cook or beverly miller 901-565-8188
Apr 23, 2010 | Fellowes Powershred 220CC Shredder
The basket full light comes on even when the basket is empty. if you hold the shred button down it will shred as long as it is pressed
needs bag full retorfit kit available from fellowes if under warranty or we have the part for sale if not under warranty cooksmobileshred@bellsouth.net
Mar 19, 2010 | Fellowes Powershred 220CC Shredder
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Jun 15, 2009 | Andis Outliner II Hair Trimmer
Shredder problems
Seems it could be a problem with one of your sensors Fellowes Customer Service can easily and quickly diagnose your problem. 1-800-945-4545
Dec 07, 2007 | Fellowes Powershred 420 Shredder
Fellowes Powershred 220CC Shredder Logo
118 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
