Question about Rowenta DZ1700 Iron
Water Leaking Water leaks out of the reservoir as I am filling....doesn't matter if it's filled when hot or cold.
  • ritabobeeta Jan 13, 2008
    Water leaks into cord retractor area
  • starched Oct 23, 2008
    The water leaks out whether I am using the iron or not. What kind of screw driver do you need for those funny screws? Can you purchase new sealing material?
The seal between the top and the bottom plate has lost it's integrity. First try tightning the 2 screws on the underside of the iron. If that doesn't fix the problem, then you will need to take the iron apart and fix the seal. That will require you to remove those 2 screws and also a third screw that is up by the toe of the iron underneath the sprayer. You will then need to slowly pull the 2 pieces apart becasue the seal is made of a sticky rubber substance. Once you get it apart, you can then distribute the seal material to cover the bad area. Then just put it back together!
Posted on Mar 05, 2008
I bought steam generator iron, iron work but doesn’t produce steam
Mix 1:1 water and white vinegar. Fill the water reservoir with mixture and hold the iron like you would normally. Keep pushing the steam button until steam comes out.
Nov 01, 2017 | Irons
How to clean brown water coming out of iron
The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
Apr 09, 2010 | Rival IR620 Iron
How do you fill the water tank on the steamer conair model GS15RN?
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Water left in steamer - need to clean clear tank
I'm willing to try this to clean the mold out of the steamer container and possibly the rest of the attachments:
1. Empty the water reservoir completely. 2. Place 20 mL of CLR or bleach into the reservoir. 3. Fill the reservoir with hot water. 4. Shake the reservoir to mix and let stand for about 1 hour. 5. Empty the reservoir completely. 6. Rinse the reservoir 3 or 4 times with cold water. 7. Fill the reservoir with distilled water. 8. Run the steamer into the ventilated air a couple of times to ensure that there is no CLR or bleach residue on the evaporation elements. Thus, there will be no bleach on your cloths.
I have the same problem and will try this out tomorrow. I will tell you how it turns out.
Mar 14, 2009 | Rowenta Compact Steamer - White
First with the iron cold fill the reservoir with white vinegar.  I would let this sit for a few hours and then pour the vinegar out of the iron. I would do this a couple of times until you see the mold is removed from reservoir. Next fill again with vinegar and run the iron on the steam setting, steaming a clean rag or towel until all of the vinegar is steamed out of the reservoir.  The vinegar will also remove any mineral deposits built up in the iron.
Next rinse the reservoir by filling it with water and emptying it completely a few times.  Follow this by filling it completely with water again and setting the iron to steam setting.  Use another clean rag or towel and steam it until all of the water has been steamed out of the reservoir.
In the future make sure to completely empty your iron after every use to prevent mineral build up and mold growth
Aug 04, 2008 | Rowenta Perfect Iron
Rowenta model DE-833 Serie C
Sounds like you need to open the iron up and look for a loose hose/clamp or crack around brass nipple to steam/water reservoir connections. If it has been leaking for some time, there may be some water deposits to help you find the leak(s).
Rowenta typically uses multi-point security Torx fasteners that may be obtained at Kragen's or Harbor Freight tools for a decent price for most DIYers. Make sure to make plenty of sketches to make it easy to reassemble and inspect everything so it is safe to use. Please keep in touch and hope this helps.
Jul 02, 2008 | Irons
Water leak from fill button
the button may have been sealed with an O-ring at one time. It may have fallen off inside the reservoir
May 10, 2007 | Rowenta Professional DX8800 Iron
Rowenta DZ1700 Iron Logo
251 people viewed this question
Top Rowenta Irons Experts
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
