Question about Dryers
Dryer wont shut off
GE Profile dryer wont shut off in auto dry modes. Board has been replaced. Service is lost after 6-plus times out here! Any suggestions? Thanks, Ron
  • 1,531 Answers
Then you may need to replace moisture sensor bar located inside the drum area usually on the front or rear of the drum area they are two silver bars
Posted on Sep 27, 2009
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Why won't my GE electric dryer shut off? My GE
The model number you submitted is not valid. Long dry times and dryer not shutting off is either an element problem, an air flow problem. Lets begin with a good model number so we can see your unit as you do...
Waiting to hear from you,Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
Apr 20, 2012 | GE Dryers
My GE profile electirc dryer wont shut off when clothes are dry?
venting issue, disconnect vent tube run dryer it will shut off, clean vent tube out.
Mar 05, 2011 | GE Dryers
GE profile dryer model # DPXR473EW0WW wont turn off on auto mode. It will turn off when on timed dry mode and if there are no clothes in it.
A faulty timer will cause the condition you described
Sounds like you have a timer malfunction and will have to be replaced because timers cannot be repaired.
Be sure to replace with the same brand/type to keep the wiring correct. Otherwise the wiring will not be the same, and you will have to follow the timer instructions on replacing the wiring in the box with the timer.
If replacing the time I HIGHLY RECOMMEND that you only remove one wire at a time, and then place that wire on the new timer. No mistakes that way.
This is a FREE answer...Please Rate Me
Sep 26, 2010 | GE Dryers
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Jan 24, 2009 | GE Profile DPSB620ECWW Electric Dryer
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
Clothes are not drying
your blower motor is probably not working. enter the troubleshooting mode by pressing and holding my cycles and help at the same time for 3 seconds. this will tell you the problem. if blower is not getting up to speed you'll have to replace it.
Dec 03, 2007 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony dryer error message
Possible Solution...
When you get message first try turning off. Open door spin drum one or two times. Close door. Power back on/start.
Works for our problem. Post if this helps.
Oct 29, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
178 people viewed this question
Top Dryers Experts
